If your Philips Sonicare ProtectiveClean 6500 isn’t powering on, has intermittent power, or not holding charge, use this guide to replace the battery.
Pry the bottom cap away from the toothbrush body.
Pry the bottom cap away from the toothbrush body until it releases.
Remove the bottom cap by hand.
Use a metal spudger to release the two retaining clips inside the device.
Slide the internal assembly out of the chassis.
Use an opening tool to gently pry up the battery.
Remove the battery.
Hello, thanks for your tutorial!
Is there others Sonicare models like this one where you don't have to desold the battery ?
It doesn’t appear you have to desolder the battery with this model. I think the diamond clean does require desoldering though.
