Philips Sonicare FlexCare UV Light Bulb Replacement
  1. Philips Sonicare FlexCare UV Light Bulb Replacement, UV Light Bulb: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before initiating the process, ensure that the sanitizer is not plugged into an outlet. Swing the door open to expose the interior of the sanitizing device.
  2. Philips Sonicare FlexCare UV Light Bulb Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grip the sides of the plastic cover that is shielding the circuitry. Pull the cover outward to remove it from the sanitizer.
  3. Philips Sonicare FlexCare UV Light Bulb Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare FlexCare UV Light Bulb Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze the sides of the guard that is placed over the UV light bulb. Pull the piece outward to remove it.
  4. Philips Sonicare FlexCare UV Light Bulb Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare FlexCare UV Light Bulb Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before holding the light bulb, ensure that it is not warm due to previous use. Once that is confirmed, take a hold of the light bulb by the threaded surface and rotate it while pulling it outward. Have a compatible UV bulb to replace the old one.
    What kind of bulb does it take?
    Ashley Taylor - crwdns2934203:0crwdne2934203:0
    I have two bulbs from #200618 and # 5615 this is my first time wanting to order replacemnts. None of the ads show the bulb number so how do I order the one I need?
    Marie Werle - crwdns2934203:0crwdne2934203:0
    The guide is very easy to follow and I appreciate the instructions.
    Where to obtain the correct bulb?
    Chris Lacher - crwdns2934203:0crwdne2934203:0
Tasha Panattoni
crwdns2935283:004/14/15crwdne2935283:0
789 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-6, Maness Spring 2015 crwdns2935289:0Cal Poly, Team 4-6, Maness Spring 2015crwdne2935289:0
CPSU-MANESS-S15S4G6
crwdns2935297:023crwdne2935297:0
I’ve had mines less than a year. The uv lamp makes a “whizz sound for a second and then stops. No noise. No light. Does the bulb needs to be replaced ? Is it normal for it to die in 9 mths?
Uroos ali - crwdns2934203:0crwdne2934203:0
I’ve had my unit for over 7 years, I was getting ready to replace it. Thanks so much, I’m not a handy person and I’m really pleased to see that I could fix this problem with your helpful advice!
roleplay1 - crwdns2934203:0crwdne2934203:0
Just changed the bulb and it still does not work :( :( :(
nicoleproulx47 - crwdns2934203:0crwdne2934203:0
Do UV bulbs need changing on a yearly basis or are they still good if giving out light?
jujsf - crwdns2934203:0crwdne2934203:0
I've had mine for close to 10 years I'm just now having to change my UV bulb
Christopher Hurtle - crwdns2934203:0crwdne2934203:0
Hi all, pls what is type of bulb and where to buyt it ?
Jaroslav Moravia - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 71
crwdns2942667:0crwdne2942667:0 12,177
