Here is how to replace the rechargeable battery in the Phillips SoniCare FlexCare HX6930. This is a difficult repair, be careful. If you see a swollen battery, follow the instructions here: What to do with a swollen battery.
Pull the brush head away from the handle to remove it.
Push the flat edge of a metal or nylon spudger between the seal and the toothbrush body and pry it open. Do this all around the edge until the seal is partially sticking out.
Have a look to an alternative opening procedure.
Using a small flathead screwdriver, release the two black locking tabs holding the internals in place
Slide the internals out of the toothbrush casing
Grab the circular, plastic base with the o-ring and pull it outward.
Remove the cap that is attached to the end of the interior by removing the two clasps that are holding it in place.
Desolder the battery from the circuit board. Here is a guide on how to desolder. Remove the old battery and replace it. Using the same guide, solder the battery in place.
The soldering points are shown in red.
crwdns2935229:042crwdne2935229:0
crwdns2947412:037crwdne2947412:0
has anyone ever done this successfully? OMG it seems daunting!!!!
I'm going to try it. Now, to find a battery source.
Anyone knows where to purchase such battery and its type/sort code?
The battery is a 14500 li-ion with soldered pins.
I bought this one without pin and will try to solder them:
http://www.ebay.de/itm/371716530024
Here, you can buy the version with pins:
mamuc -
Prying open the bottom of the brush like that can damage the plastic. There's a damage-free technique detailed on this guide:
