Philips Sonicare Essence 1 Motherboard Replacement
  1. Philips Sonicare Essence 1  Motherboard Replacement, Brush Head: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place one hand on the toothbrush handle and one on the toothbrush head.
  2. Philips Sonicare Essence 1  Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the toothbrush head from the body by twisting it in a counter-clockwise direction.
    Is there grease in the chamber that the head comes out of? Or is that old toothpaste gunk?
    Demp Dempsey - crwdns2934203:0crwdne2934203:0
    That does not tell me how to get the brush out. It doesn’t just pull out gently and I’m afraid to pull so hard I break it.
    lori thrower - crwdns2934203:0crwdne2934203:0
    After unscrewing the toothbrush head from the body, how do I get the brush out. It will not pull off.
    shirley sanford - crwdns2934203:0crwdne2934203:0
    After unscrewing the toothbrush head from the body how do I get the brush out
    Amanda Crabtree - crwdns2934203:0crwdne2934203:0
    Having the same issue cannot get the brush head out what do you need to do I see no replies from previous comments thank you
    dorotheayordy - crwdns2934203:0crwdne2934203:0
    The brush assembly just pulls out as shown. There is nothing holding it in place beyond the big plastic ring. The 'hidden' part with the magnets drops into the cavity where it is surrounded by the hidden coil that causes it to vibrate. If there is any drag it is because some toothpaste, etc, may have made its way in, but should not be a problem to simply wiggle. The toothbrush assembly is supposed to be replaced every 3 - 6 months following that same step.
    William Toperzer - crwdns2934203:0crwdne2934203:0
  3. Philips Sonicare Essence 1  Motherboard Replacement, Front Handle Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the spudger along the seem at the top of the panel.
    • Begin to pry open the panel.
  4. Philips Sonicare Essence 1  Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic pick at the top of the seam that has already been slightly pried open.
    • Continue down the seam, prying the rest of the panel open with the spudger.
  5. Philips Sonicare Essence 1  Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a soldering iron to the mount-connectors and copper-wire connectors until the motherboard can be removed.
  6. Philips Sonicare Essence 1  Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the motherboard straight up.
    I assume that the only thing that can be accomplished with this disassembly is to replace the NiMH batteries. If the toothbrush is otherwise not performing properly (stops performing the periodic timer signal, etc.), then the logic chip is failing and there is no replacement. You could look for a bad solder joint on the board that has vibrated open time.
Joseph Swindeman
crwdns2935283:011/09/17crwdne2935283:0
164 crwdns2915208:0crwdne2915208:0
IUPUI, Team S7-G1, Baechle Fall 2017 crwdns2935289:0IUPUI, Team S7-G1, Baechle Fall 2017crwdne2935289:0
IUPUI-BAECHLE-F17S7G1
Identification of the battery particulars would have been helpful to order replacement.
crwdns2942667:0crwdne2942667:0 1,687
