Philips Sonicare DiamondClean Motor Replacement
  1. Philips Sonicare DiamondClean Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare DiamondClean Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the toothbrush head off the toothbrush.
  2. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
    In einem anderen Tutorial habe ich gesehen, dass jemand mit Heißkleber eine Klebestange daran geklebt hat. Diese hatte er als Griff zum herausziehen verwendet. Durch diese Methode gibt es keine Macken am Gehäuse und man kann den Heiskleber wieder gut entfernen.
    Jens Lattke - crwdns2934203:0crwdne2934203:0
  3. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the toothbrush upside down on a solid object and firmly, but gently, push down on the toothbrush until the internal components and case separate.
    • Note that there are clips inside the case but they are hard to access and unneeded to separate the components.
  4. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubber covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a soldering iron, remove the solder from the positions marked 1 and 2 on the circuit board.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
  6. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide and separate the two components of the internals from each other.
  7. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the spring and rubber component.
  8. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4mm Phillips #00 screws on both sides of the upper component.
  9. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently bend and position the brackets to remove the motor.
  10. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motor and replace.
Caleb Watson
crwdns2935283:009/16/20crwdne2935283:0
482 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S1-G4, Eggleston Fall 2020 crwdns2935289:0The Citadel Military College of South Carolina, Team S1-G4, Eggleston Fall 2020crwdne2935289:0
CMCSC-EGGLESTON-F20S1G4
Do you have a part number for the motor?
Suraj Daryapurkar - crwdns2934203:0crwdne2934203:0
Double check if the vibrating end on step 4 is screwed tight. On my unit, I though the motor had an issue, whereas it just was that a screw on the vibrating end that had gotten loose.
Marsya Kaustentein - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 41
crwdns2936753:030crwdne2936753:0 151
crwdns2942667:0crwdne2942667:0 7,623
