This guide will show you how to replace the motor on your Philips Sonicare DiamondClean electric toothbrush. If the motor fails to produce movement or makes excessive noise during function, you may be able to restore your toothbrush by replacing the motor. The motor will need to be desoldered from the circuit board in order to be removed, so be sure to check out our How to Solder and Desolder Connections guide if you are unfamiliar with best practices!
Pull the toothbrush head off the toothbrush.
Use a spudger to pry the chrome cap from the base of the toothbrush.
In einem anderen Tutorial habe ich gesehen, dass jemand mit Heißkleber eine Klebestange daran geklebt hat. Diese hatte er als Griff zum herausziehen verwendet. Durch diese Methode gibt es keine Macken am Gehäuse und man kann den Heiskleber wieder gut entfernen.
Place the toothbrush upside down on a solid object and firmly, but gently, push down on the toothbrush until the internal components and case separate.
Remove the rubber covers from the circuit board and battery.
Using a soldering iron, remove the solder from the positions marked 1 and 2 on the circuit board.
Slide and separate the two components of the internals from each other.
Gently remove the spring and rubber component.
Remove the two 4mm Phillips #00 screws on both sides of the upper component.
Gently bend and position the brackets to remove the motor.
Do you have a part number for the motor?
Double check if the vibrating end on step 4 is screwed tight. On my unit, I though the motor had an issue, whereas it just was that a screw on the vibrating end that had gotten loose.
