Philips Sonicare DiamondClean Motor Replacement
  1. Philips Sonicare DiamondClean Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare DiamondClean Motor Replacement, Motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the toothbrush head off the toothbrush.
  2. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
  3. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the toothbrush upside down on a solid object and firmly, but gently, push down on the toothbrush until the internal components and case separate.
    • Note that there are clips inside the case but they are hard to access and unneeded to separate the components.
  4. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the rubber covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a soldering iron, remove the solder from the positions marked 1 and 2 on the circuit board.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
  6. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide and separate the two components of the internals from each other.
  7. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the spring and rubber component.
  8. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4mm Phillips #00 screws on both sides of the upper component.
  9. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently bend and position the brackets to remove the motor.
  10. Philips Sonicare DiamondClean Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motor and replace.
Caleb Watson
crwdns2935283:009/16/20crwdne2935283:0
512 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S1-G4, Eggleston Fall 2020 crwdns2935289:0The Citadel Military College of South Carolina, Team S1-G4, Eggleston Fall 2020crwdne2935289:0
CMCSC-EGGLESTON-F20S1G4
Do you have a part number for the motor?
Suraj Daryapurkar - crwdns2934203:0crwdne2934203:0
Double check if the vibrating end on step 4 is screwed tight. On my unit, I though the motor had an issue, whereas it just was that a screw on the vibrating end that had gotten loose.
Marsya Kaustentein - crwdns2934203:0crwdne2934203:0
Thank you.
Are the motors generic? Any tips on purchasing them?
Thanks.
DaveQB - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 51
crwdns2936753:030crwdne2936753:0 210
crwdns2942667:0crwdne2942667:0 8,633
