Pull the head from toothbrush.
Use a nylon spudger to pry the chrome cap at the bottom off.
Cover the toothbrush with a thin towel or some cardboard, then take a pair of pliers or channel locks and squeeze the corners to slightly deform the case. That will give you some room to get under the cap.
Use a nylon spudger to release the black tabs on either side of internals.
This is the most difficult part but it can be done once one understands how the tabs that need to be unlocked are designed and located. The difficulty is in seeing the tabs -- they are black - and especially the way they lock in, on the body.
There are two tabs - one each side - built on the internal frame holding the battery and electronic circuitry. They are pushing towards the outside, and each locks inside a recessed hole on the internal side of the toothbrush body.
They are most effectively unlocked by going deeper with the spudger and unlocking them by going behind them and hooking them from below, going in from the top opening. IMPORTANT NOTE The tabs need to be PUSHED from the outside TOWARDS the inside of the unit, i.e. towards the chassis that holds the battery and electronics. Trying to pushing the external toothbrush shaft from above will only damage the mechanism. The only way - on this latest Sonicare model- is to unlock these two black tabs.
Put the metal head on a solid surface with handle perpendicular to the surface. Firmly, yet gently, push down until the internals start to slide out.
Use a Phillips screwdriver to remove the screw at the base of the metal head.
Use fine tip tweezers to push the white plastic tabs in to release the head from the innards.
Gently pull the metal head from the innards.
Wie benennt man " den Rest des Gerätes" gemäß obiger Beschreibung? Das Gussteil ist bei mir gebrochen. Ich würde dieses gern nachbestellen. FG Reinhold
Google liefert für "hx93 Antrieb" Einiges, kommt oft aus China. Bei eBay heißt es "Vibrationsteil":
VauWeh -
crwdns2935229:09crwdne2935229:0
crwdns2944067:07crwdne2944067:0
Great guide - but where is a good source for replacement parts?
Ordered replacement part, came within 3 days at ebay. Didn’t have to replace the soft rubber inlet parts, only the connector.
Piece of cake, exchange of battery seems more labourous, but the brush still works for two weeks, so we postpone this job.
Gut beschrieben, aber wo bekomme ich eine neue Antriebsachse?
Beste Grüße - pechi606
Great post, thank-you. One question: My toothbrush has a wire loop around the head. The loop is soldered to the circuit board. Do you know what that wire is for? Cheers!
vielfach ist nur die Schraube locker - mit Loktite sichern und es hält (zumindest wieder für eine Weile)
Amazing! I fixed it. The screw holding the head on had just come loose. I tightened it and put it back together and we're off to the races.
