Philips Sonicare DiamondClean Battery Replacement
  1. Philips Sonicare DiamondClean Battery Replacement, Case Replacement: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare DiamondClean Battery Replacement, Case Replacement: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the head from toothbrush.
  2. Philips Sonicare DiamondClean Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare DiamondClean Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a nylon spudger to pry the chrome cap at the bottom off.
    Cover the toothbrush with a thin towel or some cardboard, then take a pair of pliers or channel locks and squeeze the corners to slightly deform the case. That will give you some room to get under the cap.
    Maybe Dave - crwdns2934203:0crwdne2934203:0
  3. Philips Sonicare DiamondClean Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a nylon spudger to release the black tabs on either side of internals.
    This is the most difficult part but it can be done once one understands how the tabs that need to be unlocked are designed and located. The difficulty is in seeing the tabs -- they are black - and especially the way they lock in, on the body.
    There are two tabs - one each side - built on the internal frame holding the battery and electronic circuitry. They are pushing towards the outside, and each locks inside a recessed hole on the internal side of the toothbrush body.
    They are most effectively unlocked by going deeper with the spudger and unlocking them by going behind them and hooking them from below, going in from the top opening. IMPORTANT NOTE The tabs need to be PUSHED from the outside TOWARDS the inside of the unit, i.e. towards the chassis that holds the battery and electronics. Trying to pushing the external toothbrush shaft from above will only damage the mechanism. The only way - on this latest Sonicare model- is to unlock these two black tabs.
    MASINARI - crwdns2934203:0crwdne2934203:0
    This was invaluable but I still couldnt quite picture it. So I want to add: you can see the tabs MASINARI is speaking about on the picture seen at step 6. They are the little wings at the bottom end of the 'side panels' . If you shine a light into the opened toothbrush, you should be able to see them. The holes are recessed into the shell of the toothbrush. It worked for me to push the tabs from the side downwards. Once they are lose, the body of the toothbrush will slide out of the shell with only little pressure.
    some_guy - crwdns2934203:0crwdne2934203:0
    I wrapped the open end of the base with cardboard and then with channel locks squeezed on the two short sides while pushing down on the metal brush head on a hard surface and it popped right out
    PhilR - crwdns2934203:0crwdne2934203:0
  4. Philips Sonicare DiamondClean Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare DiamondClean Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Put the metal head on a solid surface with handle perpendicular to the surface. Firmly, yet gently, push down until the internals start to slide out.
  5. Philips Sonicare DiamondClean Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove rubber covers from the top of the motherboard and the back of the battery.
  6. Philips Sonicare DiamondClean Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a soldering iron, remove the solder from the three marked spots.
    • The pins are labeled "F1", "R6", "JP1"
    Lötsin nicht entfernen !
    Nur erwärhmen und dabei druck auf die Batterie geben.
    Lötstelle JP1 nicht nötig. Nur R6 bzw Minuspol
    Felix - crwdns2934203:0crwdne2934203:0
    Translation from Felix : "Do not remove solder! Just heat it up and put pressure on the battery. Soldering point JP1 not necessary. Only R6 or negative pole"
  7. Philips Sonicare DiamondClean Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After de-soldering, the battery should be loose. If this is not the case, spend more time removing the solder.
    • When the battery comes loose, gently wiggle it out and away from the device.
  8. Philips Sonicare DiamondClean Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully reinsert the new battery into the same spot as the old one. Gently press until it is firmly pressed against the toothbrush.
    • Green batteries have a black horizontal stripe at the top on the green wrap. That is the positive terminal that goes towards the top of the unit
  9. Philips Sonicare DiamondClean Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a small amount of solder to the three points shown to attach the battery.
    Ich habe bei meiner HX9160 den Akku getauscht ohne den JP1 vorher zu entlöten und die Zahnbürste gibt keinen Ton mehr von sich. Kann ich das noch fixen?
    Christian b. - crwdns2934203:0crwdne2934203:0
    Der JP1 wird (am besten als Erstes) nur entlötet, um die Elektronik spannungsfrei zu machen. Dadurch ist sie besser vor einem Kurzschluss geschützt. Nimm halt ein Messgerät und schaue mal nach, wo du jetzt Spannung hast. Insbesondere am Mikroschalter ganz oben sollte die Akkuspannung voll anliegen.
    VauWeh -
    Oben am ein/ aus Schalter kommt nichts mehr an. Habe den Akku aber lediglich etwas unter Spannung gesetzt(mechanisch) und dann die beiden Pole angelötet. Durch die Führung kann der Pluspol aber eigentlich nirgends angelegen haben...
    Christian b. -
  10. Philips Sonicare DiamondClean Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the rubber covers on the motherboard and battery.
    • Reverse the case replacement guide to finish putting the toothbrush back together.
    Photo here is unclear, but there are two small black posts on the circuit board that the rubber cover needs to line up with. Gently press down on the cover, and be sure that the side clips (of the rubber cover) and engaging the sides of the circuit board.
    Translation from German friend/contributor which was helpful: "The instructions are a bit misleading in step 6, there are only 2 soldering points, the battery only has 2 soldering tags as you can see. One at F1, the other at R6 and JP1. The bottom arrow in the picture pointing to JP1 is wrong. I recommend completely removing the solder with a desoldering pump with a silicone tip because the battery is firmly clamped in a plastic socket and is difficult to remove only by heating the solder and there is also an IC right next to the lower soldering point. You should be very careful when soldering."
crwdns2935229:08crwdne2935229:0
Zachary Bertrand
crwdns2935283:011/20/17crwdne2935283:0
875 crwdns2915208:0crwdne2915208:0
IUPUI, Team S22-G1, Bayer Fall 2017 crwdns2935289:0IUPUI, Team S22-G1, Bayer Fall 2017crwdne2935289:0
IUPUI-BAYER-F17S22G1
I recommend to soak the bottom of the brush in a cup of warm water to make it easier to remove the bottom cap. The plastic is very easy to crack when cold.
Janson McCreery - crwdns2934203:0crwdne2934203:0
This is a decent guide. Thank you to the author! Problem is that they don't make these devices user serviceable, so we basically have to pry and force the cap off. ARGH! RIGHT TO REPAIR NOW!!
Die Anleitung ist bei Schrit 6 etwas irreführend, es sind nur 2 Lötstellen, die Batterie hat ja auch nur 2 Lötfahnen wie man sieht. Eine bei F1, die andere bei R6 und JP1. Der unterste Pfeil im Bild der auf JP1 zeigt ist falsch. Ich empfehle das Lötzinn mit einer Entlötpumpe mit Silikonspitze komplett zu entfernen da die Batterie in einer Kunststofffassung fest eingeklemmt ist und nur durch erhitzen des Lötzinns schwer herauszubekommen ist und sich direkt neben der unteren Lötstelle auch ein IC befindet sollte man beim löten sehr vorsichtig sein.
Michael - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 28
crwdns2936753:07crwdne2936753:0 172
crwdns2936753:030crwdne2936753:0 677
crwdns2942667:0crwdne2942667:0 64,012
