Philips Sonicare 9350 Battery Replacement
  1. Philips Sonicare 9350 Battery Replacement, Head removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare 9350 Battery Replacement, Head removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the toothbrush head.
    • Use a screwdriver to pry gently around the bottom of the toothbrush.
  2. Philips Sonicare 9350 Battery Replacement, Remove the bottom: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Sonicare 9350 Battery Replacement, Remove the bottom: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Sonicare 9350 Battery Replacement, Remove the bottom: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After the bottom of the toothbrush is pried loose, remove it from the base of the brush.
  3. Philips Sonicare 9350 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Sonicare 9350 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Sonicare 9350 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to open the two clasps inside the toothbrush handle in a downward motion.
    • Turn the toothbrush upside down and push down on a hard surface—this will slide the toothbrush's internal body out.
  4. Philips Sonicare 9350 Battery Replacement, Extract the internals: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare 9350 Battery Replacement, Extract the internals: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull out the internals of the toothbrush.
  5. Philips Sonicare 9350 Battery Replacement, Access the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Sonicare 9350 Battery Replacement, Access the battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the protective cover of the battery.
    • Check the battery model.
    • In this case, the model is a Sony 680mhA lithium battery.
  6. Philips Sonicare 9350 Battery Replacement, Desolder both terminals: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Sonicare 9350 Battery Replacement, Desolder both terminals: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Sonicare 9350 Battery Replacement, Desolder both terminals: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the protection cover of the circuit board.
    • Find the welding points of the positive and negative electrodes of the battery and use the soldering iron to desolder.
    • The battery will fall off after desoldering as shown in the figure.
    • Be careful not to touch other parts of the circuit board when desoldering.
  7. Philips Sonicare 9350 Battery Replacement, Install a new battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Sonicare 9350 Battery Replacement, Install a new battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Sonicare 9350 Battery Replacement, Install a new battery: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry the battery out at a 45 degree angle.
    • After successfully removing the battery, install the new battery using the reverse procedure.
    • Always use ESD safe tools when working on a circuit board or with batteries such as a nylon spudger.
crwdns2935229:05crwdne2935229:0
Dongyi Lin
crwdns2935283:005/10/21crwdne2935283:0
273 crwdns2915208:0crwdne2915208:0
York University, Team S1-G16, O'Regan Summer 2021 crwdns2935289:0York University, Team S1-G16, O'Regan Summer 2021crwdne2935289:0
YORK-O'REGAN-SU21S1G16
All good advice and it works too. Ignore Philips advice that the battery is not replaceable. It is, with correct knowledge and understanding. Thanks for posting.
Shreds - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 202
crwdns2942667:0crwdne2942667:0 12,572
