Philips Satinelle Gear Replacement
  1. Philips Satinelle Gear Replacement, Philips Satinelle Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Satinelle Gear Replacement, Philips Satinelle Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the device and remove the purple guard.
    • Remove the head by pressing the right side of the head (with the device facing away from you).
    • You will hear a 'click' and the head will become dislodged from the body of the device.
  2. Philips Satinelle Gear Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Satinelle Gear Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Satinelle Gear Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
    • Be careful not to lose the clip. It will likely fly off when it releases.
  3. Philips Satinelle Gear Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The left side will swing down.
    • Remove the Tweezers.
  4. Philips Satinelle Gear Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Satinelle Gear Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Satinelle Gear Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the plastic component that swings down.
    • Use fingernails to lift clips from stubs.
  5. Philips Satinelle Gear Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Satinelle Gear Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Satinelle Gear Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
  6. Philips Satinelle Gear Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Satinelle Gear Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Satinelle Gear Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry the gear housing unit from the base.
  7. Philips Satinelle Gear Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Satinelle Gear Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Satinelle Gear Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
  8. Philips Satinelle Gear Replacement, Gear Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the gear and re-insert the pin.
    • Ensure that pin is protruding slightly, it should not be flush.
    Where to find this gear from?
    n c - crwdns2934203:0crwdne2934203:0
Nathan Christian
crwdns2935283:011/11/17crwdne2935283:0
505 crwdns2915208:0crwdne2915208:0
IUPUI, Team S5-G5, Wilson Fall 2017 crwdns2935289:0IUPUI, Team S5-G5, Wilson Fall 2017crwdne2935289:0
IUPUI-WILSON-F17S5G5
What size pinion is used in it? Kindly help.
Wilkis James - crwdns2934203:0crwdne2934203:0
Can you send link to buy this piece?
Or 3d Printer file?
Thanks
Emilio Hernandez - crwdns2934203:0crwdne2934203:0
Tienes las medidas de los engranajes
luis vega - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,746
