Philips Satinelle Disassembly
  1. Philips Satinelle Disassembly, Philips Satinelle Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Satinelle Disassembly, Philips Satinelle Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the device and remove the purple guard.
    • Remove the head by pressing the right side of the head (with the device facing away from you).
    • You will hear a 'click' and the head will become dislodged from the body of the device.
  2. Philips Satinelle Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Satinelle Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Satinelle Disassembly: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While wearing safety glasses, use a plastic opening tool to pry from right to left to pry out the tensor clip.
    • Be careful not to lose the clip. It will likely fly off when it releases.
  3. Philips Satinelle Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The left side will swing down.
    • Remove the Tweezers.
  4. Philips Satinelle Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Satinelle Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Satinelle Disassembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the plastic component that swings down.
    • Use fingernails to lift clips from stubs.
  5. Philips Satinelle Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Satinelle Disassembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Satinelle Disassembly: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using Needle Nose pliers remove metal roller track on both sides of the Tweezers Head.
  6. Philips Satinelle Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Satinelle Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Satinelle Disassembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry the gear housing unit from the base.
  7. Philips Satinelle Disassembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Satinelle Disassembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Satinelle Disassembly: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your thumbnail and a pair of needle nose pliers to push out the gear housing retention pin.
Nathan Christian
crwdns2935283:011/11/17crwdne2935283:0
505 crwdns2915208:0crwdne2915208:0
IUPUI, Team S5-G5, Wilson Fall 2017 crwdns2935289:0IUPUI, Team S5-G5, Wilson Fall 2017crwdne2935289:0
IUPUI-WILSON-F17S5G5
can we open the lower part which holds the motor and gear..
actualy the gear which holds the motor is gone bad i think.. so i want to replace it ..
can this be fixed..??
Md Wasim Anwar - crwdns2934203:0crwdne2934203:0
Same here .. wanted to open the bottom part which holds a longish gear .. the top gear fits in a very small portion of the bottom long gear so the long gear has worn out in just that area
S Ahooja - crwdns2934203:0crwdne2934203:0
similar here, wanted to open the lower part where the cable goes in. the cable is broken at the entry.
frankgerling - crwdns2934203:0crwdne2934203:0
Thank you for this great tutorial. It really helps!
Can you please give us the dimensions for the gear’s teeth in step 7 and the corresponding gear in step 2 in the Philips Satinelle Motor Replacement tutorial? I can 3D print the gears, but I can’t find the dimensions online and the gears are simply to eroded to be able to measure them.
Albert Westhoff - crwdns2934203:0crwdne2934203:0
honestly, thank you so much from the bottom of my heart. my epilator had two threads stuck in it that I couldn't reach and it was doing a *!&*^#% $@$*!& job removing hair but then I found this guide. you saved me from having to unnecessarily buy another epilator. mine's as good as new and the best part is that I now know how to open it up again in case I have to do it once more. thanks man. ?
Sanjana T - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 101
crwdns2942667:0crwdne2942667:0 9,447
