Philips Saeco Poemia espresso machine thermostat and o-ring replacement
  1. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Introduction: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  2. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Wiring diagram: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  3. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Thermostats: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After disassembling the machine, it's easy to find the thermostats. They are attached to the top of the boiler with clips. There are two thermostats:
    • 95 ° C - brewing temperature (just below the boiling point of water)
    • 127 ° C - steaming temperature (just below the boiling point of water)
    • You can test the thermostats with a multimeter set to the resistance (ohms) setting. These thermostats are "normally-closed" which means at room temperature, the thermostat switch is closed. The meter should show close to 0 ohms when connected to the thermostat terminals.
    • You can remove the thermostats and check to see that they open when their temperature setting is reached. Carefully use a heatgun and an infrared thermometer to heat the thermostat above their set point. If you overheat them, you will melt the plastic case and destroy them. (Not that I did anything like that.... :-) )
  4. Philips Saeco Poemia espresso machine thermostat and o-ring replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  5. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Generic Thermostats: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  6. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Modify the generic thermostats: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The connectors on these generic thermostats need 2 modifications to work with the Saeco Poemia:
    • Cut/file the terminal width by about 1mm. I used a small file.
    • Bend the terminals at a right-angle to match the originals.
    • The mounting tabs are different than the original, but they work just fine under the spring clip.
  7. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Heat sink compound: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure to put some heat sink compound between the thermostat and the top of the boiler to insure accurate temperature sensing. Any low-cost type will be fine.
  8. Philips Saeco Poemia espresso machine thermostat and o-ring replacement, Testing: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After I replaced the thermostats and tested the machine, I checked the temperature of the boiler with a multimeter and temperature probe. I put the temperature probe under the thermostat clip.
  9. Philips Saeco Poemia espresso machine thermostat and o-ring replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While testing, I noticed water and steam coming out of the boiler around one of the heating element terminals. Uh oh... I took apart the boiler and replaced the silicone o-ring gaskets. The video was very helpful to disassemble and reassemble the boiler. Checked again - no leaks!
  10. Philips Saeco Poemia espresso machine thermostat and o-ring replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
Use generic thermostats to make this low-cost repair.
Wayne Seltzer
crwdns2935283:011/09/10crwdne2935283:0
1.841 crwdns2915208:0crwdne2915208:0
this is a great guide, hard to find stuff about this machine.
Sebastian Muller - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 158
crwdns2942667:0crwdne2942667:0 8,451
