Philips Respironics V60 Touchscreen Replacement
  1. Philips Respironics V60 Touchscreen Replacement, Touchscreen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • From the Diagnostics Menu, select Touch Screen Calibration. The Calibrate Touch Screen screen is displayed.
    • Follow the steps shown. Press on the middle of each target with a blunt, narrow object.
    • NOTE: If the Touch Screen Calibration button does not respond, press the Accept button on the navigation ring to begin
    • If the calibration is not successful, have the ventilator serviced.
  2. Philips Respironics V60 Touchscreen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Press and release the ON/Shutdown key, opening the Shutdown window in the screen.
    • Select Ventilator Shutdown, which will shut down the ventilator.
    • Improper shutdown may cause a Power has been restored message the next time the ventilator is turned on.
  3. Philips Respironics V60 Touchscreen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws from the end cap and remove the end cap.
    • Remove the screws from the rear bezel.
    • Separate the front and rear bezel.
  4. Philips Respironics V60 Touchscreen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect these cables from the UI PCBA: • Switch PCBA cable • Nav-ring cable • Power switch overlay cable • Touch screen cable
    • Remove the switch PCBA.
    • Remove the screw that attaches the cable clamp to the LCD tray.
    • Remove the screws and washers that attach the LCD tray to the front bezel, then remove the LCD tray.
    • Remove the touch screen from the front bezel.
Weihan Du
crwdns2935283:004/11/20crwdne2935283:0
241 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G10, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S7-G10, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S7G10
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 2,418
