Philips Respironics V60 Fan Replacement
  1. Philips Respironics V60 Fan Replacement, shut down the ventilator: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Respironics V60 Fan Replacement, shut down the ventilator: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press and release the ON/Shutdown key, opening the Shutdown window in the screen.
    • Select Ventilator Shutdown, which will shut down the ventilator.
    • Improper shutdown may cause a Power has been restored message the next time the ventilator is turned on.
    • Disconnect the ventilator from the AC power.
    • Unplug the ventilator
  2. Philips Respironics V60 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the internal battery from the power harness connector.
  3. Philips Respironics V60 Fan Replacement, Top Cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the captive D-ring fastener on the bottom of the panel counter-clockwise one-quarter turn and release.
    • Then remove the right side panel.
  4. Philips Respironics V60 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 screws using a screwdriver.
    • Remove the top cover.
  5. Philips Respironics V60 Fan Replacement, Fan: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fan mount push pins that attach the fan to the back panel.
    • Pliers may be required.
  6. Philips Respironics V60 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect fan cable from motor controller.
  7. Philips Respironics V60 Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove fan,
    • from back panel.
  8. Philips Respironics V60 Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove fan filter assembly (the fan filter and housing), from outside the back panel.
    • When installing, orient the fan with the fan cable at the top inside of the fan, and orient the fan filter and housing as shown.
Rie Kuraoka
crwdns2935283:001/23/20crwdne2935283:0
913 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G10, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S7-G10, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S7G10
crwdns2942667:0crwdne2942667:0 1,034
