Philips Respironics V60 Alarm Speaker Replacement
  1. Philips Respironics V60 Alarm Speaker Replacement, Alarm Speaker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • step 1 Remove MC PCBA
    • Remove top cover (top cover guide here)
    • Remove the screws and wing nuts that attach the MC PCBA to the PCBA brackets.
    • Loosen the captive screws that attach the capacitor bracket to the base.
    • Disconnect cables: • Blower cable • Fan cable • DA-MC ribbon cable
    • Gently pull MC PCBA up from its connection on the CPU PCBA, then disconnect speaker #1 cable.
    • Remove PCBA brackets. To reinstall, follow the steps above in reverse order
  2. Philips Respironics V60 Alarm Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • step 2 separate the UI from the base
    • Remove MC PCBA (step 1)
    • Disconnect cables: • LCD cable from PM PCBA. • LCD cable ground wires from the ground terminal. • LCD tray ground wires from the ground terminal. • UI cable (ribbon cable) from the PM PCBA.
    • Loosen the captive screw that attaches the UI retainer to the UI.
    • Slide retainer up, then remove UI from base.
  3. Philips Respironics V60 Alarm Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • step 3 remove the front panel
    • Separate UI from base (step 2)
    • Remove hose clamp and boot that attach blower to the gas outlet.
    • Remove the tubing from the barbed fittings inside the front panel.
    • Disconnect gas outlet and proximal port ground wires from the base.
    • Remove the screws that attach the front panel to the base and side walls.
    • NOTE: When reinstalling tubing, ensure that: • Longer (9-in.) tube is connected between manifold barb “M” (machine) to barbed gas outlet fitting. • Shorter (8-in.) tube is connected between manifold barb “P” (proximal) and barbed proximal pressure port.
  4. Philips Respironics V60 Alarm Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • step 4 remove the alarm speakers
    • Remove front panel (step 3)
    • Disconnect speaker #2 from the power management (PM) PCBA. (Speaker #1 is disconnected when the MC PCBA is disconnected.)
    • Remove the screw and washer that attaches each speaker to the base.
    • Insert new speaker in place of old one
    • Follow step 4 in reverse order to install speaker.
    • step 5 reinstalling
    • Follow step 3 in reverse order to reinstall the front panel.
    • Follow step 2 in reverse order to reinstall the UI to the base.
    • Follow step 1 in reverse order to reinstall the MC PCBA.
    • Follow the Top Cover Guide in reverse order to reinstall.
Weihan Du
crwdns2935283:004/11/20crwdne2935283:0
241 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G10, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S7-G10, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S7G10
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 635
