Philips Respironics System One REMstar Circuit Board Replacement
  1. Philips Respironics System One REMstar Circuit Board Replacement, Circuit Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device upside down so that the rubber feet are facing you.
    • Use a Torx TR15 screwdriver to remove the two 46.5mm screws located on the back.
    • Gently separate the panel so the wires are not damaged.
  2. Philips Respironics System One REMstar Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Torx TR10 screwdriver, remove the seven 13.5 mm screws that are securing the inner casing.
    • Lift out the inner casing.
  3. Philips Respironics System One REMstar Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motor from the bottom portion of the casing and set it aside.
  4. Philips Respironics System One REMstar Circuit Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Respironics System One REMstar Circuit Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the side panel by lifting it up out of the base.
    • Remove the grouped wire and wire connector.
  5. Philips Respironics System One REMstar Circuit Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Respironics System One REMstar Circuit Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the circular piece by popping it off to separate the circuit board from the top cover.
    • No tools should be necessary to complete this action.
  6. Philips Respironics System One REMstar Circuit Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Respironics System One REMstar Circuit Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the green, red, and white wire connectors from their connections on the circuit board.
Rachel Ross
crwdns2935283:009/16/20crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S1-G1, Eggleston Fall 2020 crwdns2935289:0The Citadel Military College of South Carolina, Team S1-G1, Eggleston Fall 2020crwdne2935289:0
CMCSC-EGGLESTON-F20S1G1
Do you happen to have a part number or link for replacement pcb?
Kyle Pierce - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,202
