Philips Norelco Shaver 2100 Battery Replacement
  1. Philips Norelco Shaver 2100 Battery Replacement, Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single screw on the back casing using a T8 Torx screwdriver.
  2. Philips Norelco Shaver 2100 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Norelco Shaver 2100 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the shaver so that it is facing you.
    • Press the button on the shaver head to open it.
  3. Philips Norelco Shaver 2100 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 10.1 mm screws inside the shaver head using a T8 Torx screwdriver.
  4. Philips Norelco Shaver 2100 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Norelco Shaver 2100 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the shaver head off of the casing.
  5. Philips Norelco Shaver 2100 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Norelco Shaver 2100 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Norelco Shaver 2100 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pull the black and blue casing apart using a metal spudger.
  6. Philips Norelco Shaver 2100 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Norelco Shaver 2100 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Norelco Shaver 2100 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry the remaining casing open using a metal spudger.
    • Be careful using a metal spudger, as it may result in damaging the case.
  7. Philips Norelco Shaver 2100 Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Norelco Shaver 2100 Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Norelco Shaver 2100 Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the clear case that holds the circuit board by lifting the latches on the sides and then pulling gently.
  8. Philips Norelco Shaver 2100 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Located directly behind the circuit board, remove the battery from the device.
crwdns2935229:014crwdne2935229:0
Marshall MacClellan
crwdns2935283:010/02/17crwdne2935283:0
419 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G4, Thompson Fall 2017 crwdns2935289:0USF Tampa, Team S1-G4, Thompson Fall 2017crwdne2935289:0
USFT-THOMPSON-F17S1G4
crwdns2947412:014crwdne2947412:0
To remove the battery you have to actually desolder both ends from the chip.
AGUSTIN CABRA - crwdns2934203:0crwdne2934203:0
What are the dimensions/specs of the battery?
Haley Pearse - crwdns2934203:0crwdne2934203:0
regular AA rechargeable batteries will not work and can be a fire hazard.
steven - crwdns2934203:0crwdne2934203:0
The tricky part is taking the case appart. You have to gently pry on tabs to get it appart. You may break some pieces which probably won’t be a problem. May make it no longer waterproof. The battery is custom but is close to a 14450 Lion battery, do searches on ebay and aliexpress you will find them. Good luck.
Don - crwdns2934203:0crwdne2934203:0
I have a similar Norelco razor and replaced the battery. I can’t believe the stupid company didn’t mark the battery polarity on the board!
I think this is the first time I have ever seen a company not mark polarity.
Laz - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 158
crwdns2942667:0crwdne2942667:0 23,241
