Philips Norelco MultiGroom 3100 Motor Replacement
  1. Philips Norelco MultiGroom 3100 Motor Replacement, Power Button: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco MultiGroom 3100 Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Norelco MultiGroom 3100 Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the attachment and twist it counterclockwise until you hear a click.
    • Pull the attachment up to remove it from the trimmer.
  3. Philips Norelco MultiGroom 3100 Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Norelco MultiGroom 3100 Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the trimmer upright so it is facing you.
    • Insert the plastic opening tool in the gap at the top of the power button.
  4. Philips Norelco MultiGroom 3100 Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply pressure to pry off the power button.
  5. Philips Norelco MultiGroom 3100 Motor Replacement, Casing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Norelco MultiGroom 3100 Motor Replacement, Casing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
    • Separate the bezel one clip at a time so that the clips do not break.
  6. Philips Norelco MultiGroom 3100 Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Norelco MultiGroom 3100 Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the spudger in the indicated hole and apply a tilting force to loosen the outer casing.
    • Pull upward on the top of the inner housing to remove it from the outer casing.
  7. Philips Norelco MultiGroom 3100 Motor Replacement, Motor: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Norelco MultiGroom 3100 Motor Replacement, Motor: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tweezers to pull out the inner power button.
  8. Philips Norelco MultiGroom 3100 Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to separate the clip on the right side of the inner housing.
  9. Philips Norelco MultiGroom 3100 Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Norelco MultiGroom 3100 Motor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the inner housing up and to the right to separate the left clip from the battery casing.
    • Push the inner housing upwards to separate it from the battery casing.
  10. Philips Norelco MultiGroom 3100 Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips Norelco MultiGroom 3100 Motor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tweezers to hold the wire steady as you unsolder the blue wire from the power switch.
    • Use the tweezers to remove the power switch.
    • For help with soldering check out the iFixit Soldering Technique Guide.
  11. Philips Norelco MultiGroom 3100 Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips Norelco MultiGroom 3100 Motor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips Norelco MultiGroom 3100 Motor Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the motor to remove it from the battery casing.
    • Use the tweezers to hold the black wire steady while unsoldering it from the base of the battery.
    • Using the tweezers, pull on the black wire to remove it from the base of the battery.
ahaharevolution
crwdns2935283:010/04/15crwdne2935283:0
819 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-1, Leahy Fall 2015 crwdns2935289:0USF Tampa, Team 1-1, Leahy Fall 2015crwdne2935289:0
USFT-LEAHY-F15S1G1
Can you help me with something?
Johan Avendaño - crwdns2934203:0crwdne2934203:0
this guide was created also by nina lovekrist in 2015
Nina Lovekrist - crwdns2934203:0crwdne2934203:0
Where can I get the motor with copper shaft?
amal.hardik - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 5,167
