Philips Infracare HP3621 bulb Replacement
  1. Philips Infracare HP3621 bulb Replacement, Remove the stand: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the flathead screwdrive beneath the plastic stand and press slightly to unfasten it.
    • Repeat on the other side, then remove the stand.
  2. Philips Infracare HP3621 bulb Replacement, Unscrew the back cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Philips screwdriver to remove the 4 screws
  3. Philips Infracare HP3621 bulb Replacement, Remove the covers: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the cover so as not to damage any wiring
    • The metal light deflector is not attached to anything, simply remove it to reach the bulb and the next step
    How can i access the bulb? The red glass is glued to the metal deflector. I have the Philips Infracare HP3621
    exus98 - crwdns2934203:0crwdne2934203:0
  4. Philips Infracare HP3621 bulb Replacement, Replace the bulb: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • That's it. Nothing fancy here. Remove the bulb by pulling it to one side. Replace with the new one.
    You need a HEAT lamp like this :
    https://www.amazon.nl/Nisbets-GH986-Infr...
    A regular halogen lamp will not work.
    Noplaceto be - crwdns2934203:0crwdne2934203:0
Joris
crwdns2935283:010/07/18crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
don’t touch the glass light bulb with your hands. use something like a tissue as the grease from you’re skin goes onto the glass and ‘fries’ when the lamp heats up. desichuck x
des.sparks - crwdns2934203:0crwdne2934203:0
Hello, thank you so much for this! It saved my Infracare, as it had fallen in an earthquake and the bulb inside was broken. I replaced the bulb with a Philips Halogen Bulb 200w R7 Linear and it is back to working again. Much appreciated!
Also, thanks to Des for the bulb handling tip. I used my dish washing gloves and a tissue to hold the bulb. Thanks!
sumant - crwdns2934203:0crwdne2934203:0
Any idea how I can replace the front screen on this device? Where could I buy one? It has ripples/lines in the red filter part showing plain white light coming through 😩😩😩
Buffy Buchanan - crwdns2934203:0crwdne2934203:0
Nowadays, it is a bit difficult to find the appropriate replacement bulb for this device. However, I could buy one made in China at RS Components (part of RS Group). RS Components has sales points in 32 countries. They sell the bulb under the Stock Number 796-0293. The original PHILIPS light bulb is said to have an operation time of about 500 hours, the spare bulb sold at RS Components is said to have an operation time of about 8000 hours.
Ernesto L. - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,008
