This guide will lead users through the process of replacing a faulty touch screen. This may be required if the touch screen is unresponsive or does not turn on.
Insert a nylon spudger underneath the top of the device.
Leverage the tool and pop off each of the eight tabs holding the plastic cover in place.
Remove the four 12.4 mm screws in each of the corners using a JIS #1 screwdriver.
Remove the top by lifting it upwards and setting it down.
Remove the back panel from the touch screen motherboard by popping the tabs off using the nylon spudger.
Does the same method apply to milex airfryer 5.6 litre xxxl ? Coz when I switch it on it does not respond
