Use this guide to disassemble the Philips HD9252 air fryer top, manufactured by Philips. Once this is removed, the main components of the device will be accessible, such as the timer and touch screen.
Insert a nylon spudger underneath the top of the device.
Leverage the tool and pop off each of the eight tabs holding the plastic cover in place.
Remove the four 12.4 mm screws in each of the corners using a JIS #1 screwdriver.
Remove the top by lifting it upwards and setting it down.
crwdns2935229:05crwdne2935229:0
thanks, now need to figure out how to repair the thin drawer switch plastic gig broken flush at the exit!
Stephane.Plaisance@telenet.be - crwdns2934203:0crwdne2934203:0
