Philips HC5450 Disassembly
  1. Philips HC5450 Disassembly, Disassembling a Philips HC5450 1415 /A: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips HC5450 Disassembly, Disassembling a Philips HC5450 1415 /A: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips HC5450 Disassembly, Disassembling a Philips HC5450 1415 /A: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • First step is to take off the front like you normally do when cleaning.
  2. Philips HC5450 Disassembly, Take off the silver bezel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips HC5450 Disassembly, Take off the silver bezel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips HC5450 Disassembly, Take off the silver bezel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry off the silver bezel. This is attached pretty firmly. Start at the front, and go all the way. The front has tabs with a large hook, so it might only fully disassemble when you have pried it loose a long way and you are able to flex the bezel a little.
    • During this step, I broke the last tab of the silver bezel. Too bad, but the bezel is still firmly attached when reassembling.
  3. Philips HC5450 Disassembly, Take out four T8 screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips HC5450 Disassembly, Take out four T8 screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T8 Torx driver to remove the four screws.
  4. Philips HC5450 Disassembly, Take apart the body: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips HC5450 Disassembly, Take apart the body: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips HC5450 Disassembly, Take apart the body: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Undo the top part of the black body. I started at the back. It is retained with clips, but is not as firmly attached as the silver bezel.
  5. Philips HC5450 Disassembly, Take out the PCB and batteries: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips HC5450 Disassembly, Take out the PCB and batteries: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips HC5450 Disassembly, Take out the PCB and batteries: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The PCB can now be taken out. The connection to the charging pins is not screwed or soldered, but a U-shaped connector that's just retained by friction.
  6. Philips HC5450 Disassembly, Take out the motor and length-adjustment-assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The assembly is held in place by one Torx T8 screw, identical to those from step 3.
    • The ring of the length-adjustment-assembly can slide down. A little pin-and-spring will fall out - don't loose it! It is used to make the "clicking" feedback when rotating the ring.
    • I did not disassemble this assembly any further.
crwdns2935229:014crwdne2935229:0
Jurrie
crwdns2935283:005/07/21crwdne2935283:0
739 crwdns2915208:0crwdne2915208:0
crwdns2947412:08crwdne2947412:0
You helped me replace batteries in otherwise completely fine trimmer. Thanks!
Anyway I also snapped the last silver clip...
Marek Ratvaj - crwdns2934203:0crwdne2934203:0
I joined ifixit just to say thank you for this. Trimmer working perfectly other than a dead battery. I just couldn't see how to get into it until I found this guide. Some advice for others:
Use the pry bar around every part of the bezel. I left the very bottom catch attached and broke it pulling on it. On the other hand, if you have to break one catch, that one is the least important.
A credit card makes a very good pry bar.
This battery seems better than the original in several ways: https://www.amazon.co.uk/dp/B0921ZJX11. It is cheaper. It is easier to install. It will likely be easier to uninstall.
Paul Gardiner - crwdns2934203:0crwdne2934203:0
Thanks for your help. All went as you described it - even the small broken pin :-)
Unfortunately I couldn’t replace the batteries, because they are welded to the PCB. Phillips don’t want the lifespan of their devises to be easily extended…
Cedric Marillat - crwdns2934203:0crwdne2934203:0
Just unsolder it from the circuit board. Obviously that requires a soldering iron and a solder sucker, but those are very useful purchases if you don't already own them. If you then replace with the battery I suggest, you wont even need the solder sucker next time you need to do the job.
Paul Gardiner -
Nice and easy to use guide, with quality images. Do you have an image showing how to reinsert the pin-and-spring please?
Mine sprung out, and can't make out how to add it back!
Tyson - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 25
crwdns2936753:07crwdne2936753:0 72
crwdns2936753:030crwdne2936753:0 550
crwdns2942667:0crwdne2942667:0 9,432
