Philips DVP642 Power Supply Replacement
  1. Philips DVP642 Power Supply Replacement, Top Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips DVP642 Power Supply Replacement, Top Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
  2. Philips DVP642 Power Supply Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips DVP642 Power Supply Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  3. Philips DVP642 Power Supply Replacement, Power Supply: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips DVP642 Power Supply Replacement, Power Supply: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the power cord out from the case.
    • Be sure not to lose the rubber clip that is wrapped around the cord.
  4. Philips DVP642 Power Supply Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ribbon attached to the power supply by pushing the latch and gently pulling up.
  5. Philips DVP642 Power Supply Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips DVP642 Power Supply Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now remove this ribbon wire by grasping the white head firmly and pulling up gently.
  6. Philips DVP642 Power Supply Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips DVP642 Power Supply Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove these two 7.5m Phillips screws and the matching set at the other end of the supply.
    • Now remove the ribbon that attaches the power supply to the motherboard by grasping the white head and gently pulling up.
  7. Philips DVP642 Power Supply Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips DVP642 Power Supply Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips DVP642 Power Supply Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the last screw.
    • Pinch this plastic prong and slide the power supply up and over it. The power supply should lift free.
  8. Philips DVP642 Power Supply Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips DVP642 Power Supply Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Your power supply is now free!
    • If the fuse circled here is blown (the small wire in the glass tube is missing or broken), remove it by pinching it tightly and pulling it straight out.
    • You can find a new fuse here.
Toby Goldsteinholm
crwdns2935283:010/09/11crwdne2935283:0
369 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 21-20, Maness Fall 2011 crwdns2935289:0Cal Poly, Team 21-20, Maness Fall 2011crwdne2935289:0
CPSU-MANESS-F11S21G20
crwdns2942667:0crwdne2942667:0 13,744
