Philips DPM8000 BA-Slider Replacement
  1. Philips DPM8000 BA-Slider Replacement, Anti-Static Wrist Strap: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    $7.95
    • Before you start disassembling your device make sure that it is turned off.
    • Put on the Anti-Static Wrist Strap and clamp the end of the band to an unpainted spot of a radiator.
  2. Philips DPM8000 BA-Slider Replacement, Battery Lid: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips DPM8000 BA-Slider Replacement, Battery Lid: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery lid
  3. Philips DPM8000 BA-Slider Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips DPM8000 BA-Slider Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery.
    • The battery lid is designed to function as an instrument for this task.
  4. Philips DPM8000 BA-Slider Replacement, Upper Ornamental Part: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips DPM8000 BA-Slider Replacement, Upper Ornamental Part: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips DPM8000 BA-Slider Replacement, Upper Ornamental Part: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the six Torx #4 (5,3 mm) screws from both sides of the device
    • Collect the removed screws in a bowl or something comparable, otherwise they might get lost.
  5. Philips DPM8000 BA-Slider Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips DPM8000 BA-Slider Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips DPM8000 BA-Slider Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the upper ornamental part from the housing.
    • If your fingernails are not long enough you can use a plastic opening tool.
    • When reassembling the device be aware that the six shackles on the sides of the upper ornamental part need to be placed inside the frame.
  6. Philips DPM8000 BA-Slider Replacement, Housing/Display: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips DPM8000 BA-Slider Replacement, Housing/Display: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the housing.
    • The display as well as the speaker are connected to the motherboard. Therefore you need to be careful not to harm those connections.
  7. Philips DPM8000 BA-Slider Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips DPM8000 BA-Slider Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unlock the connection between display and motherboard by pushing open the brown cleat.
    • It is recommended to use a spudger or a comparable tool for this step.
    • If the connection is not completely open, one of the involved components could easily be harmed.
  8. Philips DPM8000 BA-Slider Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips DPM8000 BA-Slider Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Separate the connection by pulling out the display cable.
    • If the cable does not come out easily, the connection is probably still locked.
    • When reconnecting the display to the motherboard don't forget to lock the connection, otherwise it will eventually come loose and you will have to redo the first eight steps of this guide.
  9. Philips DPM8000 BA-Slider Replacement, Speaker: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips DPM8000 BA-Slider Replacement, Speaker: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips DPM8000 BA-Slider Replacement, Speaker: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the mounting spring from the speaker with a pair of tweezers.
    • If you just want to replace the motherboard, it is recommended to ignore the steps 9 and 10.
  10. Philips DPM8000 BA-Slider Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips DPM8000 BA-Slider Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take off the safety mat from the speaker.
    • Remove the speaker from the housing.
  11. Philips DPM8000 BA-Slider Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips DPM8000 BA-Slider Replacement, Motherboard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the eight Torx #4 (5,0 mm) screws from the motherboard.
    • These two screws connect the motherboard with the sliding cage. In this guide they are removed as well. Hence this is not compulsory you can decide for yourself whether you want to remove them now or later.
  12. Philips DPM8000 BA-Slider Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips DPM8000 BA-Slider Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push in the SD-Card to eject it.
    • If the memory card remains in its slot you will not be able to remove the motherboard.
  13. Philips DPM8000 BA-Slider Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips DPM8000 BA-Slider Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Abstract the motherboard.
    • Lift up the motherboard as shown in the picture before completely removing it.
    • When inserting the motherboard first put in the side with the speaker jack on it and make sure that the microphone is placed properly under the motherboard.
  14. Philips DPM8000 BA-Slider Replacement, BA-Slider: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the sliding cage.
    • When reassembling the device please make sure that the spring in the sliding cage is positioned on the bottom side of the device.
  15. Philips DPM8000 BA-Slider Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Philips DPM8000 BA-Slider Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew one crossed slot screw PH00 (4,5 mm).
  16. Philips DPM8000 BA-Slider Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the defective BA-Slider and replace it with the new one.
To reassemble your device, follow these instructions in reverse order beginning with step 15.
Andreas Holl
crwdns2935283:011/05/15crwdne2935283:0
731 crwdns2915208:0crwdne2915208:0
Technische Universität Wien crwdns2935289:0Technische Universität Wiencrwdne2935289:0
Community
Großes Lob. Klare Anleitung. Scharfe Fotos. Gibt von 10/ 10 Punkte.
Michael Splittgerber - crwdns2934203:0crwdne2934203:0
Hab noch vergessen, was an dem Gerät war. Der Schiebeschalter ging sehr schwer. Vermutlich war irgend etwas klebriges darunter. Ich habe den Schlitten gesäubert. Er geht wieder. Vielen Dank.
crwdns2942667:0crwdne2942667:0 573
