Philips DC320 37 Headphone or Power Jack Replacement
  1. Philips DC320 37 Headphone or Power Jack Replacement, Docking entertainment system: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Headphone or Power Jack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Headphone or Power Jack Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Headphone or Power Jack Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips DC320 37 Headphone or Power Jack Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips DC320 37 Headphone or Power Jack Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Headphone or Power Jack Replacement, Headphone or Power Jack: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 5 mm Phillips #00 screws attaching white support bracket to the body of the device.
  6. Philips DC320 37 Headphone or Power Jack Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 5 mm Phillips #00 screws from green Headphone/Power electronics board to detach from white support bracket.
  7. Philips DC320 37 Headphone or Power Jack Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the white suport bracket from the headphone/power electronics board.
Graham Rolph
crwdns2935283:004/18/13crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-48, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 3-48, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S3G48
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,340
