Philips DC320 37 Connector Replacement
  1. Philips DC320 37 Connector Replacement, Docking entertainment system: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off the four white feet with the pointed end of the spudger
  2. Philips DC320 37 Connector Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Philips DC320 37 Connector Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Philips DC320 37 Connector Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips DC320 37 Connector Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips DC320 37 Connector Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
  5. Philips DC320 37 Connector Replacement, Connector: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the copper plate out of the way of the two Phillips #00 screws in the middle of the connector.
  6. Philips DC320 37 Connector Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 7 mm Phillips #00 screws holding the connector together.
    • Unscrew the four 5 mm Phillips #00 screws holding the connector to the dock
  7. Philips DC320 37 Connector Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Philips DC320 37 Connector Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Philips DC320 37 Connector Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the dock so that you are looking at the front of the dock.
    • Pull out the black U-shaped piece.
    • Pull out the iPhone/iPod support cradle.
    • Pull out the two springs.
  8. Philips DC320 37 Connector Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the dock so that you are looking at the bottom of the dock.
    • Pop out the black connector frame and attached circuit board from the body of the dock.
Greg Lane
crwdns2935283:004/16/13crwdne2935283:0
39 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-48, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 3-48, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S3G48
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,317
