This guide shows you how to replace the battery on a Philips Bodygroom Series 7000 (BG7020). It takes two 1.2V AAA NiMH batteries which can be bought online through sites such as AliExpress. Philips have intentionally made it difficult to open, so be aware that you may break some clips in the process. Mine still went back together ok and doesn’t have any issues. If you find an easier way to open the shell, please leave comments below.
Hopefully Right to Repair will stop companies like Philips from designing products like this which they intend to be thrown away and replaced when a $10 battery dies. But for now, I hope this guide helps you repair your device yourself.
Open the Trimmer Head
Remove the two screws inside
The metal clip should easily come out
Slide the Trimmer Assembly in the direction shown
It should easily remove from the base
The part in red needs to come away from the base. The Motor Assembly is attached to this red part and comes out with it
There are 6 clips (in blue) which look like they undo by sliding the housing to the right
But there are two clips (in yellow) which do not allow you to slide the housing. You would need to pry these two clips upwards to allow you to slide the housing to the right
Your assertion that this trimmer is intentionally hard to open is completely false. You're simply doing it wrong.
Fact is, this generation of the trimmer is EASIER to open up than the previous generations, IF you know how...The key to opening this trimmer is to remove the pivoting head at this stage, by pressing the two pivot pins out to the sides, until the heads protrude about 1mm. Then carefully lift the pivot out of the head, making sure you don't lose either of the two small metal clips that are on either end, or dislodge the hair springs that remain in the base of the pivot.
Having removed the pivot, look down into the slot and you'll see two screws. Remove those two screws, then slide the larger of the two external housings toward the trimmer end. Easy Peasy. No tabs need be sacrificed.
Rather than sliding the clips as intended, pry the two blue clips at the bottom to unclip them.
Then slide a spudger up the side of the housing. This will break the middle clips and the top clips, but if you didn't break the bottom two, you should be able to put it back together without any issues.
Once you've unclipped (or broken) all 6 of the blue clips, you will need to pry the yellow clips upwards with some force to remove the shell.
See my comments in the prior step. With the shaver head removed, NO clips need to be broken, or pried.
There are two screws and two clips holding the Motor Housing to the shell
Pry the clips outwards on both sides and the housing should remove from the outer shell
Remove the 4 screws holding the clear housing lid onto the base
Gently pry the clear lid away from the base. There is a rubber gasket here, but no glue. Mine was pretty easy to pry open
You will need to pry the Circuitry Housing upwards on an angle as shown
There are two clips on the inside which look like they could make it difficult, but mine came out with some gentle prying upwards and no need to touch the clips
The Battery Circuitry Housing should then remove from the Motor Housing
First you will need to desolder the + and - battery terminals
After removing all the solder, flip over the housing and gently pry the batteries upwards. There is some glue holding them down so you do have to put some effort in.
From here, you should be able to solder in the new replacement battery and reassemble the device
The new batteries should come already connected together as one unit and with the tabs needed to solder them to the board
If you are planning on making the battery yourself, I've included a few dimensions to help. I believe normal AAA batteries should fit, but I can't speak for their compatibility
Once reassembled, mine flashed red as though the battery was flat when I tried to turn it on. I plugged it in to charge and it only charged for about 10 minutes then stopped. I was then able to use it for over 30 minutes without it dying. So I assume it needs to complete a charging cycle before turning back on, even if the batteries are basically fully charged anyway.
Me ha servido. En mi caso, otro problema añadido era que uno de los pulsadores (el de cortar pelo) se quedaba pegado, y a veces la afeitadora se ponía sola a funcionar (imagina el susto cuando se activa a las 3 de la mañana), por lo que además si no estaba en casa, la batería se agotaba por completo. Lo he abierto tal cual dices en la guía, le he echado 3 en 1 al pulsador, y ya funciona!!
Muchas gracias!!!!
No sabia que se abria de esa manera el cabezal, le acabo de sacar pelos de 9 años de uso. La batería creo que no me la voy a jugar por la falta de herramientas, pero voy a consultar con un servicio técnico que ya me han arreglado otras cosas. Una consulta, el equipo mantiene su impermeabilidad pudiendo ser usada en la ducha?
