Philips BiPAP S/T Blower Replacement
crwdns2936621:0crwdne2936621:0
  1. Philips BiPAP S/T Blower  Replacement, Blower: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the UI Knob by pulling it straight out.
  2. Philips BiPAP S/T Blower  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top cover by using a Torx T15 to remove the 2 screws on the back of the enclosure.
  3. Philips BiPAP S/T Blower  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Main PCA by removing the wiring harnesses and squeezing the 2 standoffs in the corners of the board.
  4. Philips BiPAP S/T Blower  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Blower Cap by using the T8 Torx screwdriver to remove the 7 screws that secure the Cap to the enclosure.
    • Lift the Blower Assembly out of the blower housing.
    • Remove the blower Outlet Bellows from the blower assembly.
    • Place the New outlet bellows onto the blower assembly.
  5. Philips BiPAP S/T Blower  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Align the stands located on the bottom of the blower assembly with the holes in the blower housing.
Benjamin LaVigna
crwdns2935283:004/07/20crwdne2935283:0
243 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G3, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S7-G3, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S7G3
this was super helpful. i yanked a working motor/blower from a slightly older system one unit that had a dead humidifier circuit(found it had melted the connector inside) and moved it to my newer bipap unit. works great, dead silent. mine had bad bearings…so loud. great article. thank you for saving me money, time…..SLEEP!
Jon Harmon - crwdns2934203:0crwdne2934203:0
Great guide on replacing the blower assembly! It's essential to ensure that every component, like the Tournevis Torx tools, is in top shape to avoid any malfunctions. Just as in Geometry Dash, where precision is key to overcoming obstacles, the same meticulous attention is needed here. Ensure you follow each step carefully to maintain your unit's performance.
LucinaAvery - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,988
