Pfaff Tiptronic 2020 Removing top left housing cover
  1. Pfaff Tiptronic 2020 Removing top left housing cover, Remove screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Mahi Driver Kit - 48 Bit Driver Kit
    $39.95
    • The top cover is only held in place by a screw (Torx T25H) with washer. The screw is not screwed into the cover, but only clamps it in place (with the washer).
    • To see the screw, fold up the handle of the sewing machine. The screw is located approximately in the middle of the back half of the gap between the sewing machine arm and the cover on the left.
    • Use a Torx T25H screwdriver to loosen the screw.
    • Unfortunately, the bit holder of the Mahi Precision Bit Set does not fit into the narrow slot, so you need a screwdriver with a long blade. If you don't have one, you can squeeze the blunt tweezers and use them like a slotted screwdriver, which worked very well for me.
  2. Pfaff Tiptronic 2020 Removing top left housing cover, Open housing cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pfaff Tiptronic 2020 Removing top left housing cover, Open housing cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pfaff Tiptronic 2020 Removing top left housing cover, Open housing cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the cover as if you were opening a book.
    • The cover is not attached with a hinge (or anything else) at the back, so hold it firmly.
    • At the back runs the cable for the sewing light; be careful not to accidentally tear it off.
    • Release the cable for the sewing light from its 4 retaining clips on the inside of the cover with your fingers.
    • Place the cover on the sewing machine arm so that the cable is not strained.
  3. Pfaff Tiptronic 2020 Removing top left housing cover, Reattach the cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pfaff Tiptronic 2020 Removing top left housing cover, Reattach the cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To be able to reattach the cover later, align it with the housing and reinsert the cable for the sewing light into the four retaining clips.
    • Loosen the screw that clamps the cover a little more.
    • Slide the washer up to the screw head so that you can slide the plastic part of the cover underneath it. You may have to hold the washer up while doing this. This is a bit tricky; it works quite well with the pointed tweezers.
    • Replace the cover and push it as close as possible to the right side of the sewing machine arm.
    • Use a Torx T25H screwdriver (or the blunt tweezers) to retighten the screw.
Congrats! You’re done!
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0carlotremoladacrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Maria Parker
crwdns2935283:003/01/22crwdne2935283:0
18,998 crwdns2915208:0crwdne2915208:0
German Translators crwdns2935289:0German Translatorscrwdne2935289:0
Community
crwdns2931471:042crwdne2931471:0
crwdns2935297:01,539crwdne2935297:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 76
crwdns2942667:0crwdne2942667:0 1,200
