Peugeot Boxer Headlamp Bulb Replacement
  1. Peugeot Boxer Headlamp Bulb Replacement, Bonnet Catch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the passenger side door to find the bonnet release catch.
    • Pull the catch down and towards you to release the bonnet of the van.
  2. Peugeot Boxer Headlamp Bulb Replacement, Secondary Bonnet Catch: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the bonnet is loosened, find the yellow handle of the secondary bonnet catch by feeling underneath
    • Once you locate the catch, push the bonnet catch upwards, this will release the bonnet
  3. Peugeot Boxer Headlamp Bulb Replacement, Open Bonnet: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the strut, located to the right of the hood to prop open the bonnet.
    • Make sure the strut is secure to the hood! If the strut comes down, this may damage your car and strut!
  4. Peugeot Boxer Headlamp Bulb Replacement, Torx Bolts: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Peugeot Boxer Headlamp Bulb Replacement, Torx Bolts: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two Torx bolts holding the headlamp assembly at each corner.
  5. Peugeot Boxer Headlamp Bulb Replacement, Slide Headlamp Out: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently slide headlamp assembly out
    • Make sure to move the headlight diagonally towards you and towards the centre of the vehicle
  6. Peugeot Boxer Headlamp Bulb Replacement, Rubber Cap: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Peugeot Boxer Headlamp Bulb Replacement, Rubber Cap: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the tab on rubber cap, revealing the back of the headlamp bulb.
  7. Peugeot Boxer Headlamp Bulb Replacement, Disconnect Bulb: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the electrical connection from the old bulb (it should just pull off).
    • Make a note of which way up the plug was for when you connect everything back up again.
  8. Peugeot Boxer Headlamp Bulb Replacement, Remove Bulb: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With needle-nosed pliers, carefully 'wiggle' the old bulb out from its housing.
  9. Peugeot Boxer Headlamp Bulb Replacement, New Bulb: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate your new bulb. Taking care to make sure it is the right way up, push it firmly into place until you feel it clip in.
Kit Marsden
crwdns2935283:005/04/21crwdne2935283:0
544 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 53
crwdns2936753:030crwdne2936753:0 182
crwdns2942667:0crwdne2942667:0 6,575
