Petlibro Granary WIFI Feeder Technique
  1. Petlibro Granary WIFI Feeder Technique, Take it apart: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take machine apart and remove all visible screws. You need a skinny, long screwdriver for this.
    It's worth pointing out that there are some screws under the rubber feet on the base, and these are the ones that need a long, skinny screwdriver.
    Ewan Davies - crwdns2934203:0crwdne2934203:0
    Mr Davies, thanks so much. That's what I came to find out!
    Mike Kolodziej - crwdns2934203:0crwdne2934203:0
  2. Petlibro Granary WIFI Feeder Technique, Identify important wires: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The infrared sensor has an emitting diode and a receiver. note the receiver on the right side. These are the wires we will clip and attach to each other.
  3. Petlibro Granary WIFI Feeder Technique, Clip and splice: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Clip both wires leading to the receiver (green/red) and splice these together. This will bypass the infrared sensor.
    Ignore the white splice, this was done to find the correct wires.
    Matt - crwdns2934203:0crwdne2934203:0
  4. Petlibro Granary WIFI Feeder Technique, Validate bypass: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Validate that warning light is gone and device is functional before screwing everything together. We are done.
    A bit of important information was left out so I figured I’d chime in for anyone else attempting this:
    In addition the the 4 screws in the top, there are also 4 screws located under the rubber feet on the bottom. You will have to pry out the rubber feet and use a long skinny screwdriver (at least 4 inches) to remove them.
    This method does work. Thank you so much for the write up!
    GradinCheese - crwdns2934203:0crwdne2934203:0
Matt
crwdns2935283:001/06/24crwdne2935283:0
220 crwdns2915208:0crwdne2915208:0
Very helpful fix(the notation about screws’ location was key); worked perfectly. Expensive feeder is no longer a brick!
Talby - crwdns2934203:0crwdne2934203:0
solved my problem, thank you!
Thuan Pham - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 153
crwdns2942667:0crwdne2942667:0 3,134
