Has your Pet Libro Air Automatic Pet Feeder (model, PLAF008) stopped dispensing food? Let's start by cleaning the rotor it's a very common problem for food to get stuck in them. Without a clean rotor, the pet feeder won’t be able to dispense properly. It is also convenient to have a safe place to store screws while working to not lose them as they are crucial for reassembly.
Flip your device upside down.
Push in the black tab securing the battery compartment panel.
Lift up the panel.
Remove the discharged batteries and replace them with new 3 X D alkaline batteries.
Remove the four screws in the battery compartment.
After unscrewing, you’ll see the machinery inside your device.
Disconnect the attached cables.
Remove the motor.
Where can I buy the PetLibro motor replacement? Would this work for the Space Feeder as well? The door will not open to dispense the food so perhaps it has to do with the motor. I like to fix things so any feedback is welcomed.
