Pentax ZX-5n Shutter Speed Dial Replacement
  1. Pentax ZX-5n Shutter Speed Dial Replacement, Remove back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Pentax ZX-5n Shutter Speed Dial Replacement, Remove bottom cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Pentax ZX-5n Shutter Speed Dial Replacement, Remove left front cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Pentax ZX-5n Shutter Speed Dial Replacement, Remove front cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ZX-5n Shutter Speed Dial Replacement, Remove front cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Pentax ZX-5n Shutter Speed Dial Replacement, Remove right front cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 3.9 mm #00 screws.
  6. Pentax ZX-5n Shutter Speed Dial Replacement, Remove eye cup: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the eye cup up and off to access the screws underneath.
  7. Pentax ZX-5n Shutter Speed Dial Replacement, Unscrew top cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax ZX-5n Shutter Speed Dial Replacement, Unscrew top cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax ZX-5n Shutter Speed Dial Replacement, Unscrew top cover: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two 5.3 mm #00 screws by the eyepiece.
    • Remove one 6.8 mm #00 screw in the battery compartment.
    • Remove one 7.0 mm #00 screw near the take up spool.
  8. Pentax ZX-5n Shutter Speed Dial Replacement, Lift top cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the cover so it is just free of the body. It is still attached by several wires.
  9. Pentax ZX-5n Shutter Speed Dial Replacement, Discharge flash capacitors: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1kΩ-10kΩ resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
  10. Pentax ZX-5n Shutter Speed Dial Replacement, Unsolder flash connections: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unsolder one green wire.
    • Unsolder one blue wire.
    • Unsolder one brown wire.
    • Unsolder one black wire.
  11. Pentax ZX-5n Shutter Speed Dial Replacement, Unsolder remaining connections: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax ZX-5n Shutter Speed Dial Replacement, Unsolder remaining connections: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax ZX-5n Shutter Speed Dial Replacement, Unsolder remaining connections: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull black wire out from its routed location.
    • Unsolder flex connector
    • Be careful not to overheat the flex circuit. Work in short durations. Allow for cool downs in between if necessary.
    • Some repairs can be performed with the top cover still connected but the flex connection is fragile and easily damaged.
  12. Pentax ZX-5n Shutter Speed Dial Replacement, Set shutter speed dial: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the shutter speed dial to 'A'
  13. Pentax ZX-5n Shutter Speed Dial Replacement, Remove screw: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 4.3 mm #00 screw.
    • Be careful not to damage the feeler contacts for the metering switch throughout the repair. There are delicate and easily bent.
  14. Pentax ZX-5n Shutter Speed Dial Replacement, Remove contact PCB: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ZX-5n Shutter Speed Dial Replacement, Remove contact PCB: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the contact PCB.
    • There is a metal plate underneath that may stick to the PCB.
  15. Pentax ZX-5n Shutter Speed Dial Replacement, Remove dial: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the exposure compensation dial out of the top cover.
    • If the dial was not set to 'A' in Step 10, the knob will not slide out. Turning the knob at this stage could damage the detent spring.
  16. Pentax ZX-5n Shutter Speed Dial Replacement, Remove detent components: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ZX-5n Shutter Speed Dial Replacement, Remove detent components: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ball bearing from the inside of the dial.
    • Remove the detent spring from the top cover.
  17. Pentax ZX-5n Shutter Speed Dial Replacement, Remove lock button: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ZX-5n Shutter Speed Dial Replacement, Remove lock button: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to release the snaps on the lock button.
    • Remove the lock button from the top of the dial.
  18. Pentax ZX-5n Shutter Speed Dial Replacement, Remove inner components: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ZX-5n Shutter Speed Dial Replacement, Remove inner components: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove lock actuator.
    • Remove lock spring.
  19. Pentax ZX-5n Shutter Speed Dial Replacement, Reassembly notes: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tape to hold components in place when installing the dial.
Sam Gustafson
crwdns2935283:009/01/22crwdne2935283:0
7.802 crwdns2915208:0crwdne2915208:0
crwdns2935297:042crwdne2935297:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 199
