Pentax ZX-5n Mirror Motor Gear Replacement
  1. Pentax ZX-5n Mirror Motor Gear Replacement, Remove back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Pentax ZX-5n Mirror Motor Gear Replacement, Remove bottom cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Pentax ZX-5n Mirror Motor Gear Replacement, Remove left front cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Pentax ZX-5n Mirror Motor Gear Replacement, Remove front cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ZX-5n Mirror Motor Gear Replacement, Remove front cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Pentax ZX-5n Mirror Motor Gear Replacement, Remove right front cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 3.9 mm #00 screws.
  6. Pentax ZX-5n Mirror Motor Gear Replacement, Remove eye cup: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the eye cup up and off to access the screws underneath.
  7. Pentax ZX-5n Mirror Motor Gear Replacement, Unscrew top cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax ZX-5n Mirror Motor Gear Replacement, Unscrew top cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax ZX-5n Mirror Motor Gear Replacement, Unscrew top cover: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two 5.3 mm #00 screws by the eyepiece.
    • Remove one 6.8 mm #00 screw in the battery compartment.
    • Remove one 7.0 mm #00 screw near the take up spool.
  8. Pentax ZX-5n Mirror Motor Gear Replacement, Lift top cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the cover so it is just free of the body. It is still attached by several wires.
  9. Pentax ZX-5n Mirror Motor Gear Replacement, Discharge flash capacitors: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1kΩ-10kΩ resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
  10. Pentax ZX-5n Mirror Motor Gear Replacement, Unsolder flash connections: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unsolder one green wire.
    • Unsolder one blue wire.
    • Unsolder one brown wire.
    • Unsolder one black wire.
  11. Pentax ZX-5n Mirror Motor Gear Replacement, Unsolder remaining connections: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax ZX-5n Mirror Motor Gear Replacement, Unsolder remaining connections: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax ZX-5n Mirror Motor Gear Replacement, Unsolder remaining connections: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull black wire out from its routed location.
    • Unsolder flex connector
    • Be careful not to overheat the flex circuit. Work in short durations. Allow for cool downs in between if necessary.
    • Some repairs can be performed with the top cover still connected but the flex connection is fragile and easily damaged.
  12. Pentax ZX-5n Mirror Motor Gear Replacement, De-solder battery connections: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • De-solder the indicated joints. Use a solder sucker on the tabbed connections.
    • Pull the black wire from the battery flex to get more slack in the connection to the top cover.
  13. Pentax ZX-5n Mirror Motor Gear Replacement, De-solder flex posts: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a solder sucker to de-solder the four posts from the flex circuit.
    • This is the most difficult part of the repair. Patience and persistence are required.
  14. Pentax ZX-5n Mirror Motor Gear Replacement, De-solder flex connections: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unsolder film advance motor connections.
    • Unsolder sprocket counter connections.
    • Unsolder power and ground connections.
    • Unsolder panorama switch connections.
  15. Pentax ZX-5n Mirror Motor Gear Replacement, Unscrew flex circuit: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 4.3 mm #00 screw.
  16. Pentax ZX-5n Mirror Motor Gear Replacement, Lift the flex circuit: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ZX-5n Mirror Motor Gear Replacement, Lift the flex circuit: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry up the plastic carrier under the flex circuit. It may catch slightly on the battery contact tab.
    • Pay close attention to the connections around the four through-hole posts as you lift the flex. Make sure that no solder is left over and that it pulls away freely.
    • This metal tab is lightly held in place with lacquer and can easily come loose. Keep an eye on it.
  17. Pentax ZX-5n Mirror Motor Gear Replacement, Unscrew flash PCB: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 3.3mm #00 screw.
    • Remove one 3.9 #00 screw.
    • De-solder the red wire.
    • Peel off the black tape. Leave it attached to the wires.
  18. Pentax ZX-5n Mirror Motor Gear Replacement, Remove flash PCB and capacitors: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ZX-5n Mirror Motor Gear Replacement, Remove flash PCB and capacitors: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently peel the flex circuit from the surface of the capacitor.
    • There may be additional adhesive underneath the larger capacitor.
    • Lift the two capacitors and the flash PCB out as a single unit.
    • The double sided tape used to secure the capacitors can be softened with isopropyl alcohol if necessary.
  19. Pentax ZX-5n Mirror Motor Gear Replacement, Prepare bottom plate: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ZX-5n Mirror Motor Gear Replacement, Prepare bottom plate: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 3.4 mm #00 screws. Remove the plate holding the contacts in place.
    • Peel tape from the plate. Leave the tape attached to the flex circuit.
    • Remove the flex circuits from their retaining studs.
  20. Pentax ZX-5n Mirror Motor Gear Replacement, Remove bottom plate: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ZX-5n Mirror Motor Gear Replacement, Remove bottom plate: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove one 3.3 mm #0 countersunk screw.
    • Remove one 3.9 mm #0 shoulder screw.
    • Remove four 3.3 mm #00 screws.
    • Pull a little slack through the housing on this flex cable.
    • Pop the plate off its posts, rotate slightly clockwise and pull gently through the loosened flex cable.
    • To the camera tech that left me a happy little note...I see you.
  21. Pentax ZX-5n Mirror Motor Gear Replacement, Remove transport gears: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ZX-5n Mirror Motor Gear Replacement, Remove transport gears: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • It's best to remove these parts now so they don't fall out later on in the repair.
  22. Pentax ZX-5n Mirror Motor Gear Replacement, Detach DOF preview switch: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 3.8 mm #00 screw.
  23. Pentax ZX-5n Mirror Motor Gear Replacement, De-solder shutter control flex: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ZX-5n Mirror Motor Gear Replacement, De-solder shutter control flex: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • De-solder the connections.
    • Lift the flex off the retaining studs.
  24. Pentax ZX-5n Mirror Motor Gear Replacement, Remove eye piece assembly: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 5.3 mm #0 screws.
  25. Pentax ZX-5n Mirror Motor Gear Replacement, Unscrew front housing block: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ZX-5n Mirror Motor Gear Replacement, Unscrew front housing block: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 7.4 mm #0 screws.
    • Remove one 8.3 mm #0 screw.
    • Remove one 3.3 mm #00 screw. The metal bracket will be loose and should be removed as well.
  26. Pentax ZX-5n Mirror Motor Gear Replacement, Lift front housing block: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the front housing block slightly up then lift the left side up and away from the housing.
    • Proceed slowly and watch for any components that are catching. The right side is still attached by a large flex cable.
  27. Pentax ZX-5n Mirror Motor Gear Replacement, Check for shims: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There may be shims at the mounting points of the front housing block.
    • Note the positions and remove if loose.
  28. Pentax ZX-5n Mirror Motor Gear Replacement, Detach mirror motor assembly: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ZX-5n Mirror Motor Gear Replacement, Detach mirror motor assembly: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • De-solder the black wire.
    • Remove four 3.7 mm #00 screws.
    • Detach the buzzer from its mounting posts. Use isopropyl alcohol to soften the lacquer if necessary.
  29. Pentax ZX-5n Mirror Motor Gear Replacement, Remove mirror motor assembly: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grab the motor and gently wiggle the plate loose.
    • If it feels stuck, move the sliding plate down, towards the bottom of the camera
  30. Pentax ZX-5n Mirror Motor Gear Replacement, Remove mirror motor: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ZX-5n Mirror Motor Gear Replacement, Remove mirror motor: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • De-solder the red and black wires.
    • Remove two #00 screws.
    • Use the lettering on the motor to note its orientation. If installed or wired backwards, the motor will spin in the wrong direction.
  31. Pentax ZX-5n Mirror Motor Gear Replacement, Install new motor gear: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull off the old gear.
    • Press the new gear on until about 1 mm of the shaft extends past the end.
    • If it is too difficult to press on, use a soldering iron to heat the brass gear. A small amount of thermal expansion should make it easier.
  32. Pentax ZX-5n Mirror Motor Gear Replacement, Check green and yellow drive gears: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The green and yellow gears can sometimes slip off their posts while working with the motor.
    • Check that the alignment holes are properly synced before installing the mirror motor assembly.
    • Aperture set lever spring. Note this part for installation of the mirror motor assembly.
  33. Pentax ZX-5n Mirror Motor Gear Replacement, Prepare mirror motor assembly for install: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ZX-5n Mirror Motor Gear Replacement, Prepare mirror motor assembly for install: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disengage latch so the slide bar can move freely.
    • Move the slide bar about half way down its total travel.
    • Let the latch snap back into place so the slide bar is held in the new position.
    • This ensures that the aperture set lever spring couples properly with the slide bar during reassembly.
  34. Pentax ZX-5n Mirror Motor Gear Replacement, Install mirror motor assembly: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Install the mirror motor.
    • Place the left side first. Then swing the right side in, coming up and under the spring loaded lens release.
  35. Pentax ZX-5n Mirror Motor Gear Replacement, Charge mirror: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the grey gear downward until the mirror is in the charged/down position.
  36. Pentax ZX-5n Mirror Motor Gear Replacement, Charge shutter: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ZX-5n Mirror Motor Gear Replacement, Charge shutter: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the shutter charge lever upward. You should see the shutter blades move as you do this.
    • The second picture shows the shutter in the charged position. It may already be in this position and not need charging.
    • Gently place the front assembly block. Work it into place until the back of the block is flush to the back of camera.
    • Proceed with the rest of the re-assembly, following the guide in reverse.
crwdns2935229:08crwdne2935229:0
Sam Gustafson
crwdns2935283:009/01/22crwdne2935283:0
10,248 crwdns2915208:0crwdne2915208:0
crwdns2935297:057crwdne2935297:0
crwdns2947412:08crwdne2947412:0
Grazie è semplicemente perfetto
pietro mariani - crwdns2934203:0crwdne2934203:0
I went though this guide it is pretty good and easy. Thanks for your work.
Although I ended up with a camera always in dof mode. When I try to turn it off it buzzes, but the finder stays dark in smaller apertures. Any tips on that?
Szabadkai Levente - crwdns2934203:0crwdne2934203:0
It's hard to say precisely what the issue is but my guess is something around the aperture set lever. Unfortunately, I think you have to take it all apart and put it back together. Sometimes you just miss something. I would double check steps 32 and 33 and make sure those are followed during reassembly. You can also check out this video for a more in depth description of how the aperture mechanism is supposed to work. It might point you towards a more specific area.
https://www.youtube.com/watch?v=4V3x1cm-...
Sam Gustafson -
Beat Of Camera Repair Book
Patna - crwdns2934203:0crwdne2934203:0
Does this Guide work for the Pentax MZ-50? I am currently trying to fix the mirror motor gear. One problem i have is that i do not own anything to discharge the flash capacitor in Step 9, is there any way to safely discharge it with the use of a resistor? Is it possible to just let it sit without batteries installed to discharge it?
Hans Müller - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 42
crwdns2936753:030crwdne2936753:0 231
crwdns2942667:0crwdne2942667:0 7,305
