Removing the front lens board is necessary to access the internal mechanisms of the Spotmatic and/or to remove the mirror box assembly.
Remove cover screw using a spanner wrench.
Remove the self timer lever. The internal mechanism will unwind past the installed position when the lever is removed.
Apply isopropyl alcohol to the edge of the leatherette covering to soften the adhesive.
Use a dull scraper to get under the edge of the leatherette and begin peeling it off.
Fully remove the leatherette covering from both sides of the camera.
If the self timer lever can't be removed, the leatherette can be peeled away just enough to access the screws.
Remove four 4.6 mm flat head screws.
Remove one 4.3 mm flat head screws.
Lift off front lens board.
Note the position and number of shim washers at each screw location. They need to be installed in the same positions during reassembly.
There is no real need to remove the top cover in advance.
You're right. I originally included the top cover disassembly because that's the order I use for a more complete disassembly but it's not necessary to get the front cover off. And thanks for your comments elsewhere in the guides. I mention on the main camera page that the guides are for the 23102 models (the mid/late models) but it's good to have more specific notes about where they differ from early models.
