Pentax Optio WG-3 GPS Menu Button Replacement
  1. Pentax Optio WG-3 GPS Menu Button Replacement, Menu Button: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax Optio WG-3 GPS Menu Button Replacement, Menu Button: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax Optio WG-3 GPS Menu Button Replacement, Menu Button: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 6, 5 mm screws, 4 on each corner and 2 on the sides of the device.
    • One of the side screws is hidden under the top lining of the device.The lining is glued down to the device so you will have to peel the lining back using tweezers. After you are finished with your work you will have to use glue or adhesive to re-stick the lining back to the device.
  2. Pentax Optio WG-3 GPS Menu Button Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the small plastic pry tool lift the back of the camera off carefully.
    • Open the device slowly and be aware of a few flex cables that connect the mother board to the screen. These will have to be carefully disconnected before the top part is removed.
  3. Pentax Optio WG-3 GPS Menu Button Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 8, 2 mm screws from each corner of the metal button pad cover.
    • Using tweezers remove the metal cover.
    • The smaller Metal square piece on the device.
  4. Pentax Optio WG-3 GPS Menu Button Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 1, 2 mm screw near the edge of the device.
  5. Pentax Optio WG-3 GPS Menu Button Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now using tweezers, remove the menu button from its place.
    • After removing the button you can replace the entire component.
Allison Merdian
crwdns2935283:003/05/15crwdne2935283:0
422 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 11-4, Blackburne Winter 2015 crwdns2935289:0Sam Houston State, Team 11-4, Blackburne Winter 2015crwdne2935289:0
SHSU-BLACKBURNE-W15S11G4
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 517
