This guide will teach you how to properly remove the cover of the camera.
            Remove the following screws:
            Two silver 3.15mm Phillips #00 screws on the right side of the camera
            Two silver 2.08mm Phillips #00 screws on the left side of the camera
            Remove the two indicated screws on the bottom of the camera:
            The screw circled in red is a longer silver 3.15mm Phillips #00 screw
            The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
            Carefully pull the back of casing away from the front.
            Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
            To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
