Pentax MZ-S Mirror Drive Lever Replacement
  1. Pentax MZ-S Mirror Drive Lever Replacement, Remove film door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push down the latch to release the film door.
  2. Pentax MZ-S Mirror Drive Lever Replacement, Remove top cover screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Remove top cover screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Remove top cover screws: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two 7.5 mm #00 screws.
    • Remove one 9.0 mm #00 screw.
    • Remove one 13.5 mm #00 screw from inside the battery compartment.
  3. Pentax MZ-S Mirror Drive Lever Replacement, Remove top cover screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Remove top cover screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Remove top cover screws: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the button to pop up the flash.
    • Remove one 3.5 mm #00 screw.
    • Remove one 5.5 mm #00 screw.
  4. Pentax MZ-S Mirror Drive Lever Replacement, Lift top cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the top cover away from the body to access wired connections.
    • The top cover is still connected in several locations.
  5. Pentax MZ-S Mirror Drive Lever Replacement, Access flash connections: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Access flash connections: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back the corner of the rubber grip.
    • Remove the small plastic cover.
    • Be careful not to short the wires before the flash capacitors have been properly discharged.
  6. Pentax MZ-S Mirror Drive Lever Replacement, Discharge flash capacitors: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
  7. Pentax MZ-S Mirror Drive Lever Replacement, Disconnect right flex cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the sides of the white latch.
    • Hold the flex PCB on the camera body in place as you lift to prevent damaging the flex.
  8. Pentax MZ-S Mirror Drive Lever Replacement, Disconnect left flex cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the red wire.
  9. Pentax MZ-S Mirror Drive Lever Replacement, Desolder flash connections: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Desolder flash connections: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder blue, black, brown and green wires.
    • Remove the loose shim washer if present.
  10. Pentax MZ-S Mirror Drive Lever Replacement, Desolder the flash flex cable: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Desolder the flash flex cable: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the piece of cellophane tape covering the flex connections.
    • Desolder flex connetions.
  11. Pentax MZ-S Mirror Drive Lever Replacement, Remove bottom cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Remove bottom cover: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Remove bottom cover: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use isopropyl alcohol to soften the adhesive under the country plate and remove.
    • Remove one 5mm #00 screw.
    • Remove one 7.5mm #00 screw.
    • Remove two 4.5mm #00 screws.
    • Remove one 5.5mm #00 screw.
    • Remove the plastic frame around the accessory grip contacts.
  12. Pentax MZ-S Mirror Drive Lever Replacement, Remove front left cover: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 4.0 mm #00 screw.
    • Remove left cover.
  13. Pentax MZ-S Mirror Drive Lever Replacement, Remove front cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove front cover.
  14. Pentax MZ-S Mirror Drive Lever Replacement, Unscrew front right cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Unscrew front right cover: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Unscrew front right cover: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove one 6.0 mm #00 screw.
    • Remove two 3.5 mm #00 screws.
    • Remove one 5.0 mm #00 screw.
    • Remove the strap lug.
  15. Pentax MZ-S Mirror Drive Lever Replacement, Remove the front right cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the right panel away from the body. It is still attached.
    • Desolder the flex connections.
  16. Pentax MZ-S Mirror Drive Lever Replacement, Remove bottom plate: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Remove bottom plate: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Remove bottom plate: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the protective mask around the accessory grip contacts.
    • Lift the flex contacts free of their retaining posts. Use isopropyl alcohol to soften any glue or tape that is present.
    • Remove four 4.0 mm #00 screws (standard metric threads).
    • Remove four 4.0 mm #00 screws (plastic threads).
  17. Pentax MZ-S Mirror Drive Lever Replacement, Desolder speaker: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the black and red wires for the speaker.
  18. Pentax MZ-S Mirror Drive Lever Replacement, Desolder connections to bottom flex circuit: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Desolder connections to bottom flex circuit: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Desolder connections to bottom flex circuit: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Desolder the white and pink wires.
    • Desolder the red, black and gray wires.
    • Desolder the red, black and orange wires.
    • Desolder the white and blue wires.
    • Carefully peal the tape away and detach the red, black, white and blue wires from the glue. Use isopropyl alcohol to soften the glue if necessary.
    • Desolder the flex connection.
  19. Pentax MZ-S Mirror Drive Lever Replacement, Desolder connections to top flex circuit: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Desolder connections to top flex circuit: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Desolder connections to top flex circuit: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Desolder red, black, gray and orange wires.
    • Desolder flex contacts.
    • Disconnect flex connector.
    • Desolder yellow and purple wires.
  20. Pentax MZ-S Mirror Drive Lever Replacement, Desolder connections to top flex circuit: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Desolder connections to top flex circuit: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder black wire.
    • Desolder battery contact tab.
  21. Pentax MZ-S Mirror Drive Lever Replacement, Desolder flex connection above the lens mount: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Desolder flex connection above the lens mount: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder flex connection and remove from retention posts. Use isopropyl alcohol to soften the glue if necessary.
    • Carefully peal the flex cable from the surface of the flash capacitor. Use isopropyl alcohol to soften the glue if necessary.
  22. Pentax MZ-S Mirror Drive Lever Replacement, Remove eye piece assembly: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Remove eye piece assembly: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 5.0 mm #00 screws.
    • Remove the eye piece.
    • The outer cover of the eye piece is only attached with double sided tape and may come away on its own. Make sure the entire eye piece unit is removed before proceeding.
  23. Pentax MZ-S Mirror Drive Lever Replacement, Remove lens release switch: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Remove lens release switch: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove one #00 screw.
    • Reassembly Note: Ensure that the lower contact catches on the plastic nub and that the contact is open when the lens release button is not pressed.
  24. Pentax MZ-S Mirror Drive Lever Replacement, Flip the mirror up: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Flip the mirror up: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a low DC voltage (3-6 V) to the mirror motor to move the mirror to the upper position.
    • Some failures will result in the mirror appearing to be in the upper position but the internal mechanism is still "down". The mechanism still needs to be moved to release the mirror box.
  25. Pentax MZ-S Mirror Drive Lever Replacement, Detach flex circuit: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Detach flex circuit: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove one 4.0 mm screw.
    • Gently lift the flex circuit away from the housing.
  26. Pentax MZ-S Mirror Drive Lever Replacement, Unscrew the mirror box: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Unscrew the mirror box: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 6.5 mm #0 screws.
    • Remove one 8.0 mm #0 screw.
    • Remove one 4.5 mm #00 screw.
    • Remove two 2.5 mm #00 screws.
    • There may be a shim washer here. Remove if loose.
    • Remove one 4.0 mm #00 shoulder screw.
  27. Pentax MZ-S Mirror Drive Lever Replacement, Remove the mirror box: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Remove the mirror box: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the mirror box up to free it from the bottom plate.
    • Lift the left side of the mirror box and rotate it up and out of the camera body.
    • Be gentle. Keep an eye out for any snagged flex cables or wires. The right side of the mirror box is still connected to the camera body and it cannot be completely removed.
    • Check for shim washers at the mount locations. Note location and remove if loose.
  28. Pentax MZ-S Mirror Drive Lever Replacement, Remove the mirror motor plate: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Desolder the black wire.
    • Remove one 3.0 mm #00 screw securing the mount LED.
    • Remove five 3.5 mm #00 screws.
  29. Pentax MZ-S Mirror Drive Lever Replacement, Remove mirror drive lever: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Remove mirror drive lever: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two drive gears from the mirror box.
    • Remove mirror drive lever. Place a finger over the spring to prevent it from shooting away.
  30. Pentax MZ-S Mirror Drive Lever Replacement, Install new mirror drive lever: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Transfer the two springs from the old drive lever to the new drive lever.
    • Install the new drive lever.
    • Check that all the bias springs are correctly tensioned against the indicated posts.
  31. Pentax MZ-S Mirror Drive Lever Replacement, Install drive gears: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure that the indicated holes are aligned when installing the drive gears.
  32. Pentax MZ-S Mirror Drive Lever Replacement, Prepare mirror motor plate for install: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Prepare mirror motor plate for install: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the aperture actuator to the left.
    • Pinch the small lever downward and let it snap back into place.
    • The aperture actuator should be held in place on the left end of its travel if done correctly.
  33. Pentax MZ-S Mirror Drive Lever Replacement, Prepare mirror box assembly for install: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax MZ-S Mirror Drive Lever Replacement, Prepare mirror box assembly for install: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Install mirror motor plate.
    • Turn the black gear downward until the mirror moves to the upper position.
    • Continue turning the black gear until this hole appears in the opening and the shutter charge lever moves to the right.
    • Make sure all wires and flex cables are in their proper place before beginning the install. Monitor carefully to avoid pinching things in the wrong place.
    • Apply a low DC voltage (3-6 V) to the mirror motor to check the operation of the mirror box. Normal movement in the shutter blades, aperture actuator and mirror should be observable.
To reassemble your device, follow these instructions in reverse order. Be careful to route wires and flex cables in the way that they were originally assembled.
Sam Gustafson
crwdns2935283:009/01/22crwdne2935283:0
7 862 crwdns2915208:0crwdne2915208:0
crwdns2935297:049crwdne2935297:0
crwdns2947412:09crwdne2947412:0
wow, this is not for the faint of heart!
Jonas Bohatsch - crwdns2934203:0crwdne2934203:0
I need this part. Anyone know where I can find one?
salazam - crwdns2934203:0crwdne2934203:0
There is an STL file available on the main camera page, which you can send to an online 3D printing service. I would recommend using a lost wax brass casting process. Companies like Shapeways can do this for relatively cheap.
Sam Gustafson -
Hi would you be able to expand on how to discharge the flash? Where do I purchase a 1kΩ-10kΩ high power resistor? Thanks!
nateav - crwdns2934203:0crwdne2934203:0
Sure. When you are speccing out a resistor, it will have a power rating. The basic resistors that come with starter electronics kits are typically 1/4 Watt resistors. The little brown ones with the color coded stripes. These will burn up after a few uses because the capacitors can push a lot of current while they are discharging. So you want to look for a resistor with a higher power rating. I found some 20W resistors for cheap that work quite well. They are physically larger and have a white ceramic body to help dissipate the heat/power. I imagine even a 5W or 10W resistor would be sufficient. I also soldered some insulated wire to the leads so I could handle them. You do not want to be touching bare metal when you discharge the capacitors. You can find these resistors on eBay or amazon for under $10 a pack.
Sam Gustafson -
Hi! Sorry one more question. I think I’m in a little over my head and a bit nervous to do this myself. Any chance I can send it off to you to do? I have the new brass part and will of course pay for it. Let me know, thanks!
email me at samscamerabench@gmail.com
Sam Gustafson -
crwdns2936753:07crwdne2936753:0 59
crwdns2936753:030crwdne2936753:0 105
crwdns2942667:0crwdne2942667:0 1,585
