Pentax ME Super Light Meter Adjustment
  1. Pentax ME Super Light Meter Adjustment, Remove wind lever: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax ME Super Light Meter Adjustment, Remove wind lever: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax ME Super Light Meter Adjustment, Remove wind lever: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wrap a piece of masking tape around your thumb, sticky side out.
    • Turn the wind lever cap clockwise to remove (it is reverse threaded).
    • Remove the wind lever lock ring (it is also reverse threaded).
    • Remove the brass spring washer.
    • A pair of fine tipped pliers or nippers can be used in place of a spanner wrench. Be careful!
  2. Pentax ME Super Light Meter Adjustment, Remove rewind lever: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax ME Super Light Meter Adjustment, Remove rewind lever: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax ME Super Light Meter Adjustment, Remove rewind lever: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place a tool in the fork of the rewind spindle.
    • Unscrew the rewind lever.
    • Remove the lock ring with a spanner.
    • Lift off the ISO/Exposure Compensation dial.
  3. Pentax ME Super Light Meter Adjustment, Installation Notes: ISO dial: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Ensure that the ISO dial couples with the tab on the resistor.
    • Turn the Exposure Compensation to 1/4x then back to 4x while gently pushing down. This will help the dial engage with the detent mechanism properly.
  4. Pentax ME Super Light Meter Adjustment, Unscrew top cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax ME Super Light Meter Adjustment, Unscrew top cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax ME Super Light Meter Adjustment, Unscrew top cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two 3.3 mm #00 screws.
    • Remove one 3.2 mm #00 screw.
    • Remove one 2.6 mm #00 screw.
  5. Pentax ME Super Light Meter Adjustment, Unscrew top cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ME Super Light Meter Adjustment, Unscrew top cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove two 4.3 mm #00 screws.
  6. Pentax ME Super Light Meter Adjustment: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax ME Super Light Meter Adjustment: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift off the top cover. The silver trim piece is loose and may fall away.
    • Remove loose washer.
  7. Pentax ME Super Light Meter Adjustment, Installation Notes: Top Cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The shutter pin is loose. Make sure it is in place before installing the top cover.
    • The mode dial pin must be properly coupled with the mechanisms in the camera for it to work.
    • Set the mode dial to 'M'. Place the top cover on the camera. Move the mode dial to 'B' then back to 'M' while gently pushing down.
    • The mode dial should click into place and work properly.
  8. Pentax ME Super Light Meter Adjustment, Put the camera in 'Auto' mode: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax ME Super Light Meter Adjustment, Put the camera in 'Auto' mode: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax ME Super Light Meter Adjustment, Put the camera in 'Auto' mode: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Ground the right most mode contact to the camera body. This puts the camera electronics in 'Auto' mode.
    • Insert a small rod between the mode levers. This puts the mechanics of the shutter in 'Auto' mode.
    • Install the ISO dial.
  9. Pentax ME Super Light Meter Adjustment, Prepare a scene: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Create a scene that fills the viewfinder with even brightness.
  10. Pentax ME Super Light Meter Adjustment, Match indicated speed to actual speed: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax ME Super Light Meter Adjustment, Match indicated speed to actual speed: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax ME Super Light Meter Adjustment, Match indicated speed to actual speed: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The ME Super has a stepless shutter in 'Auto' mode, which means it can fire at speeds inbetween the standard one stop increments. The indicated speed may be 1/60 but the metered speed could be anywhere from 1/45 to 1/90. The shutter will fire at the metered speed.
    • Use the 1/3rd stop increments of the ISO dial to determine if the indicated value is in the center or at the edge of the possible range. Adjust until it is centered.
    • Use a shutter speed tester to check the actual speed of the shutter and compare it to the indicated speed.
    • Adjust VR2 until the measured speed matches the indicated speed.
    • VR2 only affects the indicated speed in the viewfinder. It should not change the actual speed of the shutter.
  11. Pentax ME Super Light Meter Adjustment, Adjust light meter exposure: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax ME Super Light Meter Adjustment, Adjust light meter exposure: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax ME Super Light Meter Adjustment, Adjust light meter exposure: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Mount a lens on the camera and measure the exposure for the scene with a known good light meter or camera.
    • Use a shroud to keep ambient light away from the light sensor. The light meter should only read light from the focusing screen of the camera.
    • Adjust VR1 until the metered exposure matches the correct exposure.
    • Repeat the last two steps at different exposure values for additional calibration points.
    • VR1 affects the speed of the shutter and the speed indicated in the viewfinder. They should change at the same rate.
Sam Gustafson
crwdns2935283:009/01/22crwdne2935283:0
7,832 crwdns2915208:0crwdne2915208:0
crwdns2935297:042crwdne2935297:0
Hi, do you know if moving vr1 changes the shutter speeds in manual mode? I’ve read the service manual but haven’t been able to find how to adjust the slow shutter speeds (0,5 to 4s)
Kpanga - crwdns2934203:0crwdne2934203:0
No, the manual speeds are not affected by the variable resistors. If the manual speeds are off the first step is to service the shutter (i.e. disassemble and clean the shutter). If they are still inaccurate, there is an adjustment screw on the shutter itself but it is difficult to use properly. And it's more useful for adjusting the fast speeds rather than the slow speeds as it changes the release timing of the closing curtain.
Sam Gustafson -
Hi, I just did a mirror box service on my me super but whenever I put it into manual mode and cock the shutter the LED constantly cycles from top to bottom as if the bottom button is pressed. Any ideas? I tried cleaning the contacts and took apart the cover to clean under the buttons to no avail
Trae Story - crwdns2934203:0crwdne2934203:0
Yeah, I agree. It sounds like the "decrease" button is stuck. Since you already investigated the button itself, I would look into the contact between the top cover and the body. The decrease button communicates to the camera through the middle of those three contacts. If that contact is shorted to ground, it will act like it is stuck down.
Sam Gustafson -
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 156
crwdns2942667:0crwdne2942667:0 1,145
