Pentax LX ISO Resistor Cleaning
  1. Pentax LX ISO Resistor Cleaning, Remove rewind knob: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax LX ISO Resistor Cleaning, Remove rewind knob: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place a thin tool in the rewind fork and unscrew the topside knob.
    • Remove the washer under the rewind knob.
  2. Pentax LX ISO Resistor Cleaning, Remove exposure compensation dial: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pentax LX ISO Resistor Cleaning, Remove exposure compensation dial: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pentax LX ISO Resistor Cleaning, Remove exposure compensation dial: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove three #000 5.5 mm screws.
    • Remove exposure compensation dial assembly.
    • Remove washer.
    • Remove rubber seal.
  3. Pentax LX ISO Resistor Cleaning, Remove rewind side top cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax LX ISO Resistor Cleaning, Remove rewind side top cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove one #00 X mm screw.
    • Remove one #00 2.5 mm screw.
  4. Pentax LX ISO Resistor Cleaning, Clean ISO resistor: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pentax LX ISO Resistor Cleaning, Clean ISO resistor: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The resistor assembly is crimped or pressed together and further disassembly is not possible.
    • Use a cotton bud and isopropyl alcohol to clean the surface of the resistive element.
    • Spray a plastic safe contact cleaner in the area of the feeler contacts.
    • Rotate the dial back and forth several times.
    • Check the resistance between the purple wire and ground. It should range from 7.5 kΩ to 200 kΩ with no dead spots.
  5. Pentax LX ISO Resistor Cleaning, Replace ISO resistor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the resistor still doesn't function properly after cleaning, remove it a replace it with a new part.
    • Unsolder one purple wire.
    • Unsolder one green wire.
    • Unsolder two brown wires.
    • Remove three #00 screws.
Sam Gustafson
crwdns2935283:009/01/22crwdne2935283:0
10 248 crwdns2915208:0crwdne2915208:0
crwdns2935297:057crwdne2935297:0
Hi Sam, I have to congrat with you, your guides are the most detailed guides concerning LX issues. I also try to repair some LX, always with success! Unfortunatly, I have a new LX, that I'm not able to fix...the camera still always "on". I thought it could depend by main switch setting; I try to modify the contacts position without success. I Don't know where it could be located the issue. Did you ever had experience with similar issues? How do you eventually solve the problem?
Francesco - crwdns2934203:0crwdne2934203:0
Yeah, my first guess for this kind of issue was also a bad switch contact. While this can sometimes be the source, it's more often a fault in the main PCB. A component failure. The only way I've heard of resolving it is by replacing the entire main PCB. But I'm hopeful that we will eventually learn more about the design of the main PCB and be able to identify exactly which component is responsible for the failure. It would be much easier to replace a bad capacitor than to source an entire PCB.
Sam Gustafson -
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 347
