Penguin FZ-8 28” Tower Fan Blade Replacement
  1. Penguin FZ-8 28” Tower Fan Blade Replacement, Fan Blade: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the fan onto its side so that you can access the base of the fan.
    • Remove the single 11 mm screw using a Phillips #1 screwdriver.
  2. Penguin FZ-8 28” Tower Fan Blade Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Penguin FZ-8 28” Tower Fan Blade Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Penguin FZ-8 28” Tower Fan Blade Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the base of the fan counter-clockwise to detach it from the rest of the fan. The base can be separated into two parts.
  3. Penguin FZ-8 28” Tower Fan Blade Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Penguin FZ-8 28” Tower Fan Blade Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four 5 mm screws from the sides of the base of the fan using the Phillips #1 screwdriver.
  4. Penguin FZ-8 28” Tower Fan Blade Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Penguin FZ-8 28” Tower Fan Blade Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 5 mm screws located on the outside of the case inside the holes using the Phillips #1 screwdriver.
  5. Penguin FZ-8 28” Tower Fan Blade Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Penguin FZ-8 28” Tower Fan Blade Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove a single 5 mm screw on the outside cover of the fan using the Phillips #1 screwdriver.
    • Gently lift the top cover of the fan halfway to expose the single 5 mm screw. Remove this screw using the same Phillips #1 screwdriver.
  6. Penguin FZ-8 28” Tower Fan Blade Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Penguin FZ-8 28” Tower Fan Blade Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the sides of the case to remove the case from the rest of the fan.
  7. Penguin FZ-8 28” Tower Fan Blade Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 5 mm screw between the fan blade and the motor using the Phillips #1 screwdriver.
  8. Penguin FZ-8 28” Tower Fan Blade Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Penguin FZ-8 28” Tower Fan Blade Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 5 mm screws holding the fan blade in place using the Phillips #1 screwdriver.
  9. Penguin FZ-8 28” Tower Fan Blade Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fan blade from the device and clean it off before reassembling your device.
Ethan
crwdns2935283:003/22/21crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G4, Riel Spring 2021 crwdns2935289:0UMass Dartmouth, Team S2-G4, Riel Spring 2021crwdne2935289:0
UMASSD-RIEL-S21S2G4
crwdns2942667:0crwdne2942667:0 1,412
