Pebble Time Steel Battery Replacement
Aadi Bhamidipati
crwdns2944107:0crwdnd2944107:0Aadi Bhamidipaticrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Kul 9, 2025crwdne2944111:0
crwdns2931289:01crwdne2931289:0
crwdns2937803:0crwdne2937803:0
crwdns2944444:0crwdne2944444:0
crwdns2942287:0crwdne2942287:0
Hey folks! Just thought I'd write something up here, since there doesn't seem to be much in the way of explaining a battery replacement on a Time Steel, and the differences between the Time etc.
So the first question - you can use the Pebble Time Battery Replacement Guide (linked here), the main difference however is that the LCD on the Time Steel is bonded to the front cover, so definitely avoid separating those if you can.
The most useful information I've found on the web is actually in this Reddit Thread here: https://www.reddit.com/r/pebble/comments..., where they talk about what batteries fit etc and what to do/what not to do - it's tight, and there are a few ways to make it work, but definitely worth pre-reading and having an idea what you're getting yourself into. I would recommend grabbing a 3.8v battery rather than a 3.7v one, so that the capacity % works properly post-installation.
Finally, I've also just posted some pictures up of the replacement I just did with a few notes, photos here: https://imgur.com/gallery/V4SUvbz.
Also, be careful if you haven't taken anything apart before, as this one is a tid-bit fiddly. If you've taken a few phones apart you'll be familiar with the niggles and things moving around and small screws that aren't magnetic etc, otherwise if it's your first repair just be weary that the soldering is fiddly and it's very easy to drop screws especially since they aren't magnetic.
Hopefully this helps someone!
crwdns2944105:0crwdne2944105:0
  1. Pebble Time Steel Battery Replacement, Screen Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the watch flat on your workstation.
  2. Pebble Time Steel Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Steel Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
    Just a note whilst removing the cover/screen - on my Pebble Time Steel, the LCD seemed to actually be attached to the glass, so when the adhesive around the outside seperated, I disconnected the ribbon cable and removed both as one piece - if you can, this definitely helps keep the end result a bit tidier!
    Aadi Bhamidipati - crwdns2934203:0crwdne2934203:0
  3. Pebble Time Steel Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Steel Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Steel Battery Replacement, Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Steel Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Steel Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pebble Time Steel Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pebble Time Steel Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
    There might be some yellow / brown sticky tape that covers the lower end of the ribbon cable and those 6 shiny contact pads. You can carefully pull it off when you lift up the cable.
    Henrik L - crwdns2934203:0crwdne2934203:0
  8. Pebble Time Steel Battery Replacement, Circuit Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Keep the watch flat on your workstation.
  9. Pebble Time Steel Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the three screws on the circuit board.
    • Remove using the J000 Philips head screwdriver.
  10. Pebble Time Steel Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pebble Time Steel Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pebble Time Steel Battery Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
    • Move apart the connector to expose the fourth screw.
  11. Pebble Time Steel Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
  12. Pebble Time Steel Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Steel Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
    • Remove the circuit board from the case.
  13. Pebble Time Steel Battery Replacement, Battery: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the circuit board, the battery is located in the middle of the case.
  14. Pebble Time Steel Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Steel Battery Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the battery connector on the left side of the case.
    • Carefully disconnect the wire using a metal spudger.
  15. Pebble Time Steel Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Steel Battery Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After disconnecting the battery use the plastic opening tool to lift the battery off of the case.
    • The battery might be glued to the case.
    The connector might also be glued to the case with doublesided sticky tape.
  16. Pebble Time Steel Battery Replacement, Battery Flex Cable: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Steel Battery Replacement, Battery Flex Cable: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The original battery (note my lovely swollen one here) has a special flex cable attached to it that's soldered onto the battery - if you're up for it, desoldering this cable is probably the cleanest/easiest way to install.
    • There are two contact points (second photo) in the middle that need to be de-soldered and re-soldered, and as you can see they are quite small and fiddly, and you don't want to bridge the two because they're connected to a live battery unfortunately.
  17. Pebble Time Steel Battery Replacement, Trimming Battery Leads: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pebble Time Steel Battery Replacement, Trimming Battery Leads: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pebble Time Steel Battery Replacement, Trimming Battery Leads: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Something that I didn't do originally is to trim the battery leads - comparing the photos, you can see how much excess there is. This makes re-assembling the watch easier as there is less excess wire to tuck away and find space for.
    • I also didn't get a photo of the battery just on its own, to show just how long the leads are, but they're about 3 or 4cm I'd say. In terms of the length I ended up trimming them to, it was approximately 1 length of the top of the battery (the yellow taped portion in the last photo).
    • If you haven't potentially having a look at the Reddit thread linked in the Introduction is a good idea, as it gives you context for just how tight these batteries are to install, and how important selecting the right battery is, as well as knowing what you're getting yourself into!
  18. Pebble Time Steel Battery Replacement, Insulating Solder Points: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Steel Battery Replacement, Insulating Solder Points: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you've soldered the battery flex on, make sure to insulate your solder points else they'll ground out on the case, which wouldn't be good. Also, as you can probably see electrical tape is a bit too stiff for this application, so Kapton Tape is much better if you have it (or can get it).
    • Unfortunately when I re-did my battery due to this one failing, I forgot to grab a photo showing how it's supposed to be done!
  19. Pebble Time Steel Battery Replacement, Replace Battery/Battery Flex Adhesive: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure to replace the adhesive under the battery, especially if your new battery comes with some, but also replace the adhesive under the battery flex cable - this helps it stay in place, and makes installation a lot easier. You can see in the picture the new adhesive (with the peel still on) that's ready for its new life in the case.
  20. Pebble Time Steel Battery Replacement, Button Cleaning/Adjusting: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Steel Battery Replacement, Button Cleaning/Adjusting: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you haven't already, now is a really good time to check your buttons and clean them, to make sure they work properly whilst you're in there (before you put the board in preferably, I happened to only take the photos afterwards - writing guides is hard!)
    • You'll see on each of the buttons on the casing that there is a little circlip on each, that should sit in a detent - double check/verify that it's where it should be, as otherwise this can make the button hard to press and not return to its normal position as well. There's also a write up here on iFixit that's great for the buttons.
  21. Pebble Time Steel Battery Replacement, Put It Back Together: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Steel Battery Replacement, Put It Back Together: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now it's time to put it all together - for the most part, you can go back up this guide and use the steps in the reverse order as standard, however since I had excess lead length, I found it easier to install the Battery Flex Cable, then to install the Motherboard, and finally to tuck away all the excess lead and install the battery.
    • With the excess lead, I tucked this in slightly underneath and parallel to the inner left edge of the motherboard (where the two ribbon connectors are). The battery still fits reasonably well, but as you can see there is quite a lot of excess to store. The other battery I installed (last photo) is much better in this respect, with thinner wires.
  22. Pebble Time Steel Battery Replacement, Test Before Final Reassembly: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Steel Battery Replacement, Test Before Final Reassembly: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you adhesive everything back together, now is a good time to test that everything works as it should, and that your Pebble boots/vibrates etc. You can also see me reusing photos here, since I wasn't planning on making this guide when I replaced the battery in my watch - this just sort of happened later!
    • Also, installing that LCD Ribbon cable is a pain. Be prepared for that, and take your time as always. Use a spudger to press down and seat the connector. I found it easier to get the connector seated by moving the display to the right (2nd photo), and you can also get a side on view of the connector to check if the pins are lining up as well.
    • If you haven't got a plastic spudger, I'd highly recommend you grab one and use it to press down on the connector to seat it, otherwise you can damage the connectors (I've done it before, learned the hard way).
  23. Pebble Time Steel Battery Replacement, A Quick Note On Adhesives: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Steel Battery Replacement, A Quick Note On Adhesives: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This seems to be something most people struggle with - what to attach the screen back on with. Tesa Tape is a good option, otherwise in my first replacement I actually used a spare LCD Adhesive set I had lying around (refer to next step). My best idea was to use some Apple Watch Series 5 (44mm) adhesive, and cut it down.
    • One note is to not use the red heat-to-melt Apple Watch Adhesives (first photo), as this was my original plan, which unfortunately didn't work. I've found commonly the adhesives themselves don't actually say they're heat to melt, but you can tell from the colour.
    • Over the coming steps, I would highly recommend putting the adhesive on the main frame rather than the top cover, as it's much easier to align and get it in the right places. There are two nibs (top and right when looking down at the Pebble) that need to be adhesive free, as they clip into holes in the top cover for alignment.
  24. Pebble Time Steel Battery Replacement, Option 1: DIY Tesa Method: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • For this one, essentially you place and cut a guide using Tesa 61395 to make your own adhesive. Having just pulled apart another broken Pebble for parts, my guess is that the adhesive is perhaps 1mm thick, but then compressed down for a quality bond.
    • It's worth noting if you go down this route, take the time to acquire genuine Tesa Tape (61395) - the knock-offs are nowhere near as good, and Pre-Cut Adhesive also doesn't really hold up the same way either. In essence, nothing else compares!
  25. Pebble Time Steel Battery Replacement, Option 2: Apple Watch S5 (44mm) Adhesive Method: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pebble Time Steel Battery Replacement, Option 2: Apple Watch S5 (44mm) Adhesive Method: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pebble Time Steel Battery Replacement, Option 2: Apple Watch S5 (44mm) Adhesive Method: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Here's what I ended up using on my last re-assembly (30 mins ago as of writing this). This Apple Watch S5 (44mm) adhesive is pre-cut, and fits the corners of the PTS reasonably well. It is however a bit long, so I cut it about 3/4 down, applied the top half, and then cut the bottom half to size and applied it to meet flush.
    • It's also worth noting that this adhesive is quite thin, and needs to be triple-stacked to make contact with the top frame. I found two was too thin, whilst four was too thick! Fortunately, they come in packs of 5.
  26. Pebble Time Steel Battery Replacement, Adhesive Installed: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Steel Battery Replacement, Adhesive Installed: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Here's me having installed the adhesive. On the DIY Tesa Method (first photo), the fit wasn't quite perfect, but Tesa Tape is quite flexible, and so can be curved slightly once the backing is removed so that it fits in the channel. Tweezers are quite helpful for this however!
    • The 2nd photo is the results of the Apple Watch Adhesive Method, which I'm really happy with overall - this is with the adhesive applied (3 layers), and the backing on both sides removed. You can see it just fits the PTS, but you do have to be accurate with the placement.
  27. Pebble Time Steel Battery Replacement, Re-Test, Re-Attach, And Celebrate!: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pebble Time Steel Battery Replacement, Re-Test, Re-Attach, And Celebrate!: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pebble Time Steel Battery Replacement, Re-Test, Re-Attach, And Celebrate!: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Re-test the LCD once you've attached the adhesive and before you seal it up, and then you're good to go! Once it's back together, I also like to heat up the Tesa Tape/device slightly and apply light pressure so that the tape gets tacky and does begin to stick both sides together consistently.
    • You can also see from the 2nd picture that the LCD/Cover do sit quite flush with Tesa Tape (DIY Method), and seem to seat/seal well, so hence why it's my preferred option (aside from the Pebble being designed for similar stuff). The 4th photo shows the results after the Apple Watch Adhesive Method, which seems to sit even more flush.
    • But otherwise, you're done! Enjoy your new watch battery - also, a shameless Pebble Nav Me plug in there as well!
    • Make sure to calibrate your new battery by charging it fully, draining it fully, and then charging it until full again. And then, enjoy! (You must enjoy, that is an instruction, not a request).
To reassemble your device, follow these instructions in reverse order (ish). In theory, if you've made is this far, you should be give or take done - enjoy your new(ish) Pebble!
Aadi Bhamidipati
crwdns2935283:007/25/21crwdne2935283:0
348 crwdns2915208:0crwdne2915208:0
Thanks for the helpful guide! Managed to use the official ifixit battery replacement for the pebble time steel, and also managed to attach it directly to the battery PCB and fanangle it to fit. I’m not super proud of the bend in the flex PCB for the battery, but it’s working again so can’t complain.
Raymond Tu - crwdns2934203:0crwdne2934203:0
No worries! Glad you managed to get it to work, as the photos really don't do it justice as to just how tight it is when you're trying to fit it all in there :D
Aadi Bhamidipati -
I'm counting on this guide to get me through. Thank you for a thorough post with other links. My addition as perhaps a too fastidious newby is to scrape the old thin black adhesive off the case top and the thick black plastic spacer attached to the frame. Plastic spudger did most of the work after I was lucky to be able to slowly pull of strings of adhesive. After the spudger stopped working, I careful rubbed my thumb along the black plastic spacer to get the remaining schmutz off. I have small hands like Donald Trump, so if you are a manly man (or woman) don't rub on the guts of the case, or better yet, don't try to do this till you get the guts out! Duh!
Also if anyone is wondering like me where to start prying to open up the case, there is a slight indent just under the top of the case that you might not notice without bright lights. There is no other place to pry. Also I carefully used my guitar pick, very shallowly insert to kind of cut through the adhesive almost all the way around.
Christopher Holly - crwdns2934203:0crwdne2934203:0
There are a couple of tabs sticking up from the bottom frame that fit into recesses in the top. You won't be able to slide around those. And really, don't insert the guitar pick, if you use it, more than 1/8" (3 mm for rest of universe). Goal is to make it a little easier to pry top up, not to disembowel your precious watch!
OK, pay attention to what screws you are removing. The goal is to remove the circuit board. There are screws nearby that do not do that, like in the bottom right corner. And guess what? All these itty-bitty screws are a bear to install. A tardigrade bear! Oh, in my toolkit, the screw driver bit is labeled PH000. Don't try to use the Y000 - whatever that is for!
Christopher Holly -
Great write up! I ended up soldering the battery leads directly to the main board since I didn't feel comfortable soldering directly to the battery. I'm not thrilled with the board flex either (similar to Raymond Tu), and hope the solder points don't break over time. Otherwise, repair went very well and used tesa tape for mounting the display.
Sebastien De La Cruz - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 37
crwdns2936753:030crwdne2936753:0 159
crwdns2942667:0crwdne2942667:0 3,846
