crwdns2959928:0crwdne2959928:0 ↓Replacement guide for the screen of the Pebble Time.
Lay the watch flat on your workstation.
Use the metal spudger to carefully pull apart the screen cover from the case.
Replace the metal spudger with a plastic opening tool to hold the cover open.
Use the metal spudger tool to carefully loosen the rest of the cover.
Carefully, pull apart the cover with the plastic opening tool.
Insert metal spudger into the side of the screen shown in the picture.
Use the metal spudger to pry the screen up.
Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
Disconnect the screen from the circuit board.
Where can I buy the display replacement?
ulises - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hello Ulises,
Based off of my search, I couldn’t find any place where you can buy a display replacement. I advise you to look on Ebay, Amazon, or you can contact Pebble Time for more information at https://www.pebble.com or +18882245820. If none of this works out for you, you might want to check local tech repair shops.
Hope this helps.
Saud Al-Malki - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hola.
¿I have a question ?
What adhesive What adhesive should I buy to stick it again after placing the screen?
bladimir gonzalez matos - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
These are bad instructions. I broke my screen because this tutorial said the screen would come off the front glass. it's glued. >:-(
clymer17 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
