Pebble Time Round E-Paper Display Replacement
  1. Pebble Time Round E-Paper Display Replacement, Glass Screen Protector: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge an opening tool between the case of the watch, and the glass screen bezel.
    • Pry the screen bezel away from the device.
    • If you have a difficult time getting the front bezel to separate from the case, try warming the watch up with a hair dryer.
    • There are three very tiny springs that are compressed between holes in the case and the front bezel. They can pop out once the bezel is removed, so don't lose them! Remove them and put them somewhere safe once the bezel is removed.
  2. Pebble Time Round E-Paper Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the screen protector away from the device, breaking glue sealant.
    • Separate the screen protector from the screen.
    • To re-seal the glass protector's glue, simply heat the glue.
  3. Pebble Time Round E-Paper Display Replacement, E-Paper Display: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a prying tool between the bezel ring and the e-paper screen. Move the tool around the circumference of the ring until it separates from the e-paper screen.
  4. Pebble Time Round E-Paper Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Round E-Paper Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slightly lift the screen and you will see a yellow cable that connects to the motherboard.
    • Use a pair of tweezers to carefully pull the cable up from the motherboard to disconnect it.
  5. Pebble Time Round E-Paper Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to disconnect the small yellow wire from the top of the e-paper screen.
    • The wire is connected with a bit of glue, so it will come off with ease.
Jonathan Carreiro
crwdns2935283:010/30/21crwdne2935283:0
219 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021 crwdns2935289:0UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021crwdne2935289:0
UMASSD-GULBRANDSEN-F21S4G5
crwdns2942667:0crwdne2942667:0 755
