Pebble Time Round Battery Replacement
Will Tourinho
crwdns2944107:0crwdnd2944107:0Will Tourinhocrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Dzi 8, 2024crwdne2944111:0
crwdns2931287:010crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2944105:0crwdne2944105:0
  1. Pebble Time Round Battery Replacement, Glass Screen Protector: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge an opening tool between the case of the watch, and the glass screen bezel.
    • Pry the screen bezel away from the device.
    • If you have a difficult time getting the front bezel to separate from the case, try warming the watch up with a hair dryer.
    • There are three very tiny springs that are compressed between holes in the case and the front bezel. They can pop out once the bezel is removed, so don't lose them! Remove them and put them somewhere safe once the bezel is removed.
  2. Pebble Time Round Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the screen protector away from the device, breaking glue sealant.
    • Separate the screen protector from the screen.
    • To re-seal the glass protector's glue, simply heat the glue.
    Hi, love the instructions! One question though: What method/temperature are we talking for heating it to adhere it again? Mine fell off. I have a hair blow dryer, but what’s too hot for the electronics themselves?
    Ro Bo - crwdns2934203:0crwdne2934203:0
    I have the same question! My screen just popped off and a hairdryer didn't do a thing so I'm not sure what 'just heat the glue' means or if I need to replace the glue cause it's lost something.
    jex - crwdns2934203:0crwdne2934203:0
  3. Pebble Time Round Battery Replacement, E-Paper Display: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a prying tool between the bezel ring and the e-paper screen. Move the tool around the circumference of the ring until it separates from the e-paper screen.
  4. Pebble Time Round Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Round Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slightly lift the screen and you will see a yellow cable that connects to the motherboard.
    • Use a pair of tweezers to carefully pull the cable up from the motherboard to disconnect it.
  5. Pebble Time Round Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to disconnect the small yellow wire from the top of the e-paper screen.
    • The wire is connected with a bit of glue, so it will come off with ease.
  6. Pebble Time Round Battery Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three screws that hold the motherboard down using a Phillips #000 screwdriver.
  7. Pebble Time Round Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cable connecting the motherboard vibration motor, microphone, and light sensor.
    • Remove the motherboard from the device.
  8. Pebble Time Round Battery Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the small plastic iFixit opening tool from to lift the battery out of the device.
  9. Pebble Time Round Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the watch.
    What happens if you lose the springs?
    I disassembled my watches yrs ago & they're put back somewhere. I'm sure I've lost the springs by now.
    I'm thinking about buying a battery & replacing it in one of em. If the springs are necessary for the watch to function, I'm not gonna bother.
    I kinda doubt that's the case tho.
    Will it work without the springs?
    Heather Hodge - crwdns2934203:0crwdne2934203:0
crwdns2935229:05crwdne2935229:0
Will Tourinho
crwdns2935283:010/28/21crwdne2935283:0
199 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021 crwdns2935289:0UMass Dartmouth, Team 4-5, Gulbrandsen Fall 2021crwdne2935289:0
UMASSD-GULBRANDSEN-F21S4G5
Worked great. Was able to fully remove the battery from my wife’s original dead Pebble Round. I did lose one of the tiny springs cause man those things are tiny and springy…
Daniel Houghtaling - crwdns2934203:0crwdne2934203:0
Great guide! Very detailed and informative. Here is a replacement battery for the Pebble Time Round:
Pebble Time Round Battery SP301618AE
It comes with all the necessary tools and carries a 1 year replacement warranty!
Mike - crwdns2934203:0crwdne2934203:0
I have followed each of these steps but my watch will not take a charge. It boots to a screen with a plug pointing to lightning and won’t display anything else. Have I done something wrong when reconnecting the battery or is the battery not viable?
Jeff Gorvette - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 112
crwdns2942667:0crwdne2942667:0 4,487
