Pebble Time Battery Replacement
  1. Pebble Time Battery Replacement, Screen Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay the watch flat on your workstation.
  2. Pebble Time Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the metal spudger to carefully pull apart the screen cover from the case.
    • Replace the metal spudger with a plastic opening tool to hold the cover open.
    Just a note whilst removing the cover/screen - on my Pebble Time Steel, the LCD seemed to actually be attached to the glass, so when the adhesive around the outside seperated, I disconnected the ribbon cable and removed both as one piece - if you can, this definitely helps keep the end result a bit tidier!
    Aadi Bhamidipati - crwdns2934203:0crwdne2934203:0
  3. Pebble Time Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the metal spudger tool to carefully loosen the rest of the cover.
  4. Pebble Time Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully, pull apart the cover with the plastic opening tool.
  5. Pebble Time Battery Replacement, Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert metal spudger into the side of the screen shown in the picture.
  6. Pebble Time Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the metal spudger to pry the screen up.
  7. Pebble Time Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pebble Time Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pebble Time Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once screen is lifted, insert plastic opening tool between the screen connector and circuit board.
    • Disconnect the screen from the circuit board.
    There might be some yellow / brown sticky tape that covers the lower end of the ribbon cable and those 6 shiny contact pads. You can carefully pull it off when you lift up the cable.
    Henrik L - crwdns2934203:0crwdne2934203:0
  8. Pebble Time Battery Replacement, Circuit Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Keep the watch flat on your workstation.
  9. Pebble Time Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the three screws on the circuit board.
    • Remove using the J000 Philips head screwdriver.
  10. Pebble Time Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pebble Time Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pebble Time Battery Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully disconnect the connector wire on the bottom left edge of the circuit board using a plastic opener tool.
    • Move apart the connector to expose the fourth screw.
  11. Pebble Time Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the final screw from the circuit board with a J000 Philips head screwdriver.
  12. Pebble Time Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Battery Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the watch to the side and use the plastic opening tool to lift up the circuit board.
    • Remove the circuit board from the case.
  13. Pebble Time Battery Replacement, Battery: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the circuit board, the battery is located in the middle of the case.
  14. Pebble Time Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Battery Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the battery connector on the left side of the case.
    • Carefully disconnect the wire using a metal spudger.
  15. Pebble Time Battery Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Time Battery Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After disconnecting the battery use the plastic opening tool to lift the battery off of the case.
    • The battery might be glued to the case.
    The connector might also be glued to the case with doublesided sticky tape.
crwdns2935229:033crwdne2935229:0
Nicolas Hempe
crwdns2935283:002/15/17crwdne2935283:0
1.468 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-3, Sullivan Spring 2017 crwdns2935289:0USF Tampa, Team 1-3, Sullivan Spring 2017crwdne2935289:0
USFT-SULLIVAN-S17S1G3
crwdns2947412:011crwdne2947412:0
Where did you purchase the replacement battery?
Dimas Caparros - crwdns2934203:0crwdne2934203:0
Got mine on Amazon
kwojdak -
What is everyone using for sticky tape to hold the bezel/crystal on that will ensure the pebble is still waterproof?
Shannon Oswald - crwdns2934203:0crwdne2934203:0
Attempted this using RTV Silicon, and it is %#*@ difficult to not get it EVERYWHERE! I got some on my LCD, now I’m looking for another Pebble. Just use a little superglue on the outside and don’t figure on it being waterproof anymore - I guess.
There’s a lot of replacement battery on internet. Just search “150mAh P11G7T-01-S01”.
Xie Yanbo - crwdns2934203:0crwdne2934203:0
Amazing tutorial, i just completed it and everything went fine! I wanted to mention that i used the T-7000 glue to hold both the replacement battery and the screen back in place, hopefully restoring to some degree the water resistance feature of the watch.
Oscar Acevedo - crwdns2934203:0crwdne2934203:0
Failed. The spudger slipped inside and damaged the screen. Kept trying for the heck of it, removing the screws is also very difficult, as they are tiny and the screwdriver easily damages the head, to the point where they won’t turn anymore. All in all a !&&* of a job, very high likelihood of failure, more trouble than it is worth.
Massimo Boninsegni - crwdns2934203:0crwdne2934203:0
Attempted and failed due to screws getting stripped and not budging.
David Millar - crwdns2934203:0crwdne2934203:0
This is trickier than it sounds.  Add to the tool list a pair of tweezers (for placing screws), a tiny flat blade screwdriver (for prying and pressing), and a knife blade (for prying the case apart).  A pair of magnifying glasses is a help, too.  The Phillips screwdriver for the screws and plastic pry tools came with my Amazon battery: https://www.amazon.com/dp/B07XLVC6J4?psc....  Cost was around $15.
The small yellow ribbon connectors came off easily but were fussy to get back on, especially the folded one for the LED screen.  Clean any fingerprints/debris off the LED screen and the inside lens of the cover and turn the watch on before replacing the cover to make sure all the connections are in place.
I used some black silicone cement around the lip of the cover, but also ran into problems with it getting everywhere.  The top didn’t snap into place, so I clamped the top and case together while the silicone cured.  We’ll see if it stays. If not, I'll try superglue like another commenter.
Ron LaMee - crwdns2934203:0crwdne2934203:0
I was wondering if I would be able to do this as my DIY skills are crap, but surprisingly all went well. Take time and make sure you have the correct tools.
Michael Hirst - crwdns2934203:0crwdne2934203:0
Hey folks! Awesome guide, just for those who are using this to replace a battery in a Pebble Time Steel (or even a regular time), I've found there's some useful info in this reddit thread here: https://www.reddit.com/r/pebble/comments..., especially with battery sizes etc.
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 180
crwdns2942667:0crwdne2942667:0 24,125
