Pebble Steel Vibration Motor Replacement
  1. Pebble Steel Vibration Motor Replacement, Internal Hardware: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Pebble Steel Vibration Motor Replacement, Internal Hardware: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Pebble Steel Vibration Motor Replacement, Internal Hardware: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Torx T3 screwdriver to unscrew the four 3.5 mm Torx T3 screws holding the back plate.
    • Make sure the screws are kept in a safe place to insure they are not lost.
    • Remove the back plate.
  2. Pebble Steel Vibration Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Pebble Steel Vibration Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The plastic frame is clipped inside the steel body with four clips, two each on the left and the right side of the watch, near the corners. You can stick a small screwdriver into the cutouts right above the clips and gently lever the plastic frame up, corner by corner.
    • Once the clips are released, use a pair of tweezers to grab onto the black plastic frame and remove the internal hardware.
    • Adhesive on the back side of the battery holds the internal components to the front case.
    • Use tweezers or a plastic opening tool to disconnect the ribbon cable from the motherboard.
  3. Pebble Steel Vibration Motor Replacement, Vibration Motor: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a small plastic opening tool to remove the vibration motor from the motherboard.
  4. Pebble Steel Vibration Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to detach both the blue and red wires from the motherboard.
Orlandria Heggs
crwdns2935283:010/01/15crwdne2935283:0
545 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-7, Leahy Fall 2015 crwdns2935289:0USF Tampa, Team 1-7, Leahy Fall 2015crwdne2935289:0
USFT-LEAHY-F15S1G7
Any idea where I can get the vibration motor ?
Armacalypse Roguewind - crwdns2934203:0crwdne2934203:0
Do you think these would be ok as a replacement for my pebble (original, first gen.) http://www.ebay.it/itm/5-Motorino-Motore...
cerebro84 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,503
