crwdns2959928:0crwdne2959928:0 ↓Is your Pebble Steel not vibrating properly? Replacing the vibration motor may solve this problem.
Use a Torx T3 screwdriver to unscrew the four 3.5 mm Torx T3 screws holding the back plate.
Remove the back plate.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
The plastic frame is clipped inside the steel body with four clips, two each on the left and the right side of the watch, near the corners. You can stick a small screwdriver into the cutouts right above the clips and gently lever the plastic frame up, corner by corner.
Once the clips are released, use a pair of tweezers to grab onto the black plastic frame and remove the internal hardware.
Use tweezers or a plastic opening tool to disconnect the ribbon cable from the motherboard.
Use a small plastic opening tool to remove the vibration motor from the motherboard.
Use a pair of tweezers to detach both the blue and red wires from the motherboard.
Any idea where I can get the vibration motor ?
Armacalypse Roguewind - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Do you think these would be ok as a replacement for my pebble (original, first gen.) http://www.ebay.it/itm/5-Motorino-Motore...
cerebro84 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
