crwdns2959928:0crwdne2959928:0 ↓Are the buttons on your Pebble Steel not responding anymore? This could result from the inner sensors being worn down. Replacing the inner Zebra ribbon may fix this problem.
Use a Torx T3 screwdriver to unscrew the four 3.5 mm Torx T3 screws holding the back plate.
Remove the back plate.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
The plastic frame is clipped inside the steel body with four clips, two each on the left and the right side of the watch, near the corners. You can stick a small screwdriver into the cutouts right above the clips and gently lever the plastic frame up, corner by corner.
Once the clips are released, use a pair of tweezers to grab onto the black plastic frame and remove the internal hardware.
Use tweezers or a plastic opening tool to disconnect the ribbon cable from the motherboard.
Starting in the top right corner, use a pair of tweezers to remove the white film.
Continue pulling off the attached orange Zebra ribbon and the inner sensors attached to the ribbon.
crwdns2947412:09crwdne2947412:0
Where do I get a new zebra ribbon? I can't fond any on the intetnrt?
Knocky ledwell - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I also can't find the zebra cable. Any information on this?
eliasp02 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Generally I'm a big fan of iFixit and the tear down guides but this one is seriously lacking. Firstly, there is no indication of where to get replacement parts. I understand that Pebble do not have a solution to supply repair parts to the market meaning that a tear down is a pointless exercise as the item is junk if it's broken. There also aren't any third party suppliers that I can see. The next problem with this one is that during disassembly the button ribbon cable was torn and it seems no mention was made that it is now unusable. More photos are required and a big warning that the cable will tear easily when pulling it away from the adhesive.
Otherwise keep up the good work ifixit
Martin Le Tessier - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This tutorial isn’t so good. It’s missing parts and where the !&&* you got a new zebra cable?
Emilio Jéldrez - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
If the buttons are not working. The only way to fix the issue is to solder a small wire on the zebra ribbon. I did it and the buttons are working fine again.
Nicolas V. - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
